BT.com
Wishlist
Targus VUSCAPE FOR IPAD 3 FAUX LEATHER
Delivery
Standard Due date unavailable
Targus Vuscape cases feature a form fitted design which holds and protects your iPad. A durable exterior for high performance protection combines with a super soft inner lining to protect your iPad screen. Vuscape cases are equipped with magnetic closure on the front cover which immediately wakes up your iPad and then shuts down after use, as well as a new integrated stylus loop which allows you to securely store your stylus. The case easily transforms into a hands free stand with a choice of different viewing and typing positions. The lightweight design makes the case easy to carry and offers access to all your iPad features and functions while still inside the case.
Targus VuScape Protective Cover & Stand - protective cover for tablet
Protective cover for tablet
Notebook & Tablet Compatibility
9.7"
19.5 cm x 29 cm x 3 cm
0.55 kg
Europe
Material
Lychee polyurethane leather
Apple iPad (3rd generation)
19.5 cm
29 cm
3 cm
0.55 kg
Material
Europe
Carrying Case
Protective cover
Recommended Use
For tablet
9.7"
Protection
Scratch resistant
Closure Type
Magnetic closure
Inner Dimensions
18.57 cm x 24.12 cm x 0.88 cm
Cover Features
Stand function
Lifetime
Scroll to top
