BT.com
Wishlist
Targus USB 3.0 SuperSpeed Multi Monitor Adapter
Targus USB 3.0 SuperSpeed Multi...
£58.51
£58.51
Add to wishlist
Delivery
Standard Due date unavailable
Expand your view and connect your laptop to an external monitor via USB 3.0 SuperSpeed enabling instant connectivity and superb picture quality between your laptop and additional monitor. Choose between extending your desktop onto the secondary monitor to view two different applications at the same time, mirroring your laptop screen, or switching off your laptop screen and using the external monitor as your main screen. The multi monitor adapter offers improved productivity and combined with Targus USB 3.0 SuperSpeed Dual Video Docking Station you can support three external monitors, tripling your view.
Targus USB 3.0 SuperSpeed Multi Monitor Adapter external video adapter - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Max Resolution
2048 x 1152
Max Monitors Supported
6
DVI-I , VGA - with adapter
9.3 cm x 5.4 cm x 1.8 cm
Enclosure Colour
2 years warranty
Bus Type
SuperSpeed USB 3.0
Max Resolution
2048 x 1152
6
USB powered
Microsoft Windows Vista (32/64 bits) SP1, Microsoft Windows XP (32/64 bits) SP2, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Windows 8
1 x SuperSpeed USB cable ¦ 1 x DVI-VGA adapter
Software Included
Drivers & Utilities
FCC, RoHS
9.3 cm
5.4 cm
1.8 cm
90 g
Enclosure Colour
Scroll to top
