Click to visit BT.com
BT.com
Wishlist
Targus Stylus for Apple iPad, Tablets & Smartphones - Black
Quicklinx: 8GLTWS00
Mfr#: AMM01AEU
The Targus Stylus for iPad is specially designed to complement the Apple Smart Cover colour. This stylus makes it easy to take notes, draw or simply turn a page. Using the stylus keeps screen clean of smudges and fingerprints. The stylus features a durable rubber tip that won't scratch the iPad's surface and allows the user to type accurately and comfortably.
The stylus engages directly with your electronic, touch-screen device, requires no power or software to operate and instantly works right out of the box.
Features:
Designed to complement the Apple Smart Cover; allows users to type accurately and comfortably; use to take notes, draw or turn a page; soft, durable rubber tip won't scratch screen
Compatibility:
Works on all capacitive touch surfaces; use with iPad, iPod Touch, iPhone and other touch-screen devices
NB: iPad not included
Targus Stylus - stylus
Stylus
Product Material
Plastic, copper
0.8 cm x 0.8 cm x 13 cm
14 g
2 years warranty
Apple iPad (3rd generation); iPad 1; 2; iPad mini; iPad with Retina display (4th generation)
Stylus
Product Material
Plastic, copper
0.8 cm
0.8 cm
13 cm
14 g
2 years warranty
Service & Support Details
2 years
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPad mini , Apple iPad with Retina display (4th generation)
