BT.com
Wishlist
Targus Stylus for Apple iPad, Tablets & Smartphones - Black
Delivery
Standard Due date unavailable
The Targus Stylus for iPad is specially designed to complement the Apple Smart Cover colour. This stylus makes it easy to take notes, draw or simply turn a page. Using the stylus keeps screen clean of smudges and fingerprints. The stylus features a durable rubber tip that won't scratch the iPad's surface and allows the user to type accurately and comfortably.
The stylus engages directly with your electronic, touch-screen device, requires no power or software to operate and instantly works right out of the box.
Features:
Designed to complement the Apple Smart Cover; allows users to type accurately and comfortably; use to take notes, draw or turn a page; soft, durable rubber tip won't scratch screen
Compatibility:
Works on all capacitive touch surfaces; use with iPad, iPod Touch, iPhone and other touch-screen devices
NB: iPad not included
Targus Stylus - stylus
Stylus
Product Material
Plastic, copper
0.8 cm x 0.8 cm x 13 cm
14 g
2 years warranty
Apple iPad (3rd generation); iPad 1; 2; iPad mini; iPad with Retina display (4th generation)
Stylus
Product Material
Plastic, copper
0.8 cm
0.8 cm
13 cm
14 g
2 years warranty
Service & Support Details
2 years
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPad mini , Apple iPad with Retina display (4th generation)
Scroll to top
