BT.com
Wishlist
Targus Multimedia USB Presenter
£35.55
15 in stock
£35.55
Add to wishlist
Delivery
Standard 3-5 working days
Don’t fumble around with wires or fuss over the computer; present like a professional and control your computer remotely, using just one device – the Targus Multi Media Presentation Remote with Cursor Control. Thanks to the remote’s 2.4GHz cordless technology, you can access programmes, launch the internet, adjust volumes and playmusic and videos, all fromup to 15metres away. The Targus MultiMedia Presentation Remote will give you the freedom to concentrate on your Microsoft PowerPoint™or Apple Keynote™ presentation, without having to worry aboutmakingmistakes – the system’s patented KeyLock Technology locks non-essential keys,meaning you can’t press them accidentally.Walk around and take the presentation at your own pace. You can even dimthe lights if necessary as the remote has backlit buttons for use in low-light environments. The easy-to-guide and cursor controls will enable you to access your computer and move your presentation along smoothly and efficiently. The mini USB receiver stores neatly inside the remote when it’s not in use for added convenience, so it won’t get lost or damaged. The versatile systemis compatible with Mac, PC and netbooks and you don’t need special drivers or software. Present the professional way with the Targus Multi Media Presentation Remote with Cursor Control.
Targus Multimedia Presentation Remote - presentation remote control
Presentation remote control
Enclosure Colour
Grey, black
3.8 cm x 12.1 cm x 2.5 cm
140 g
Europe
Radio
Supported Devices
Notebook, personal computer
Max Operating Distance
15 m
Standard - AAA type
3.8 cm
12.1 cm
2.5 cm
140 g
Enclosure Colour
Grey, black
Enclosure Material
Plastic
Europe
Radio
Supported Devices
15 m
Built-in laser pointer, voice control, KeyLock Technology
USB receiver
Standard - AAA type
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.76
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.41
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.60
£14.36
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.64
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.87
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£59.58
Scroll to top
