BT.com
Wishlist
Targus Ergo D-Pro Laptop Stand
£73.09
14 in stock
£73.09
Add to wishlist
Delivery
Standard 3-5 working days
The Ergo D-Pro Notebook Stand has multiple tilt positions to hold your notebook in a vertical position to allow the notebook LCD to be used as the display. The height adjustment feature ensures you position the LCD screen in the most ergonomic position for your eye-line. Additional features include a compartment that can store a mobile docking station or USB hub and a document holder which is positioned directly in front of the notebook user. A rotating base is also included to allow you to share your notebook screen with someone sitting next to you. Compatible with all PC and Mac notebooks up to 17". Must be used in conjunction with a separate keyboard.
Targus Ergo D-Pro Notebook Stand - notebook stand
Notebook stand
Silver, dark grey
Product Material
Plastic
33 cm x 31 cm x 25 cm
2.95 kg
Notebook Compatibility
17"
Adjustable height
2 years warranty
Notebook stand
Product Material
Plastic
33 cm
31 cm
25 cm
2.95 kg
17"
Silver, dark grey
Adjustable height
Scroll to top
