BT.com
Wishlist
Targus Compact Universal Monitor Stand
Targus Compact Universal Monitor...
£36.14
15 in stock
£36.14
Add to wishlist
Delivery
Standard 3-5 working days
The Universal Monitor Stand allows you to regain valuable desktop space by elevating your external monitor to a more ergonomically correct height and housing your notebook computer and docking station in the same space that your monitor used to occupy. To access your notebook you simply pulling out the convenient sliding tray. The open architectural design provides quick access to all of your notebook computer’s PC Card slots, bays, diskette and DVD/CD-ROM drives. The stand will support an external monitor weighing up to 40 Kg. It also includes a riser that will allow the customer to raise the monitor stand height (from 85 mm to 136 mm). This stand is perfect for the home or the office.
Targus Universal Monitor Stand monitor stand
Monitor stand
Black, silver
48.5 cm x 35.5 cm x 16.5 cm
2.5 kg
2 years warranty
Monitor stand
48.5 cm - 35.5 cm - 16.5 cm
2.5 kg
Black, silver
Adjustable height
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Excellent well built product.
Reviewed by Anonymous on 15/04/2010
This is an excellent well built product. The stand actually has two heights 12.5cm plus the 16.5cm quoted.
I have got my 22" LCD monitor mounted on it and it looks great. The sliding tray fits my 15" laptop perfectly (My laptop is 14" wide - larger laptops would not fit).
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 2X1T 036067
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£5.06
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
