BT.com
Wishlist
Targus Compact Laptop and Tablet USB Charger - UK
Targus Compact Laptop and Tablet...
£49.98
£49.98
Add to wishlist
Delivery
Standard Due date unavailable
The Targus Compact Charger for Laptop & USB Tablet is a 90 watt adapter that allows you to quickly charge a laptop and USB tablet or smartphone at the same time from a wall socket. Sized for travel, this charger is 25% smaller than most conventional power adapters and comes with a 2.1A USB fast charging port that connects with your USB devices charging cable providing the same charging speed as your original charger. Featuring built-in surge protection to keep all of your mobile devices safe from unexpected surges and spikes, this reliable adapter includes 7 connector tips to support Acer, Compaq, Dell, HP, IBM, Lenovo, Sony and Toshiba right out of the box. This charger is also compatible with iPad, iPad 2, iPhone, BlackBerry, Android and other tablet and phone devices with a USB charging capability.
Targus Compact Laptop & USB Tablet Charger - power adapter - 90 Watt
Power adapter - external
198 g
United Kingdom
Power Capacity
90 Watt
Output connectors
1 x 4 pin USB Type A (power only) , 1 x power DC jack
7 notebook power tips
12 cm x 6.7 cm x 17.2 cm
2 years warranty
United Kingdom
Input Voltage Range
AC 100 - 240 V
Frequency Required
50/60 Hz
Max Electric Current
4.61 A
Power Capacity
90 Watt
1 x USB - 4 pin USB Type A (power only)
Power cable
Over current protection, over voltage protection, short-circuit protection
12 cm
6.7 cm
17.2 cm
198 g
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.70
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£20.20
£14.67
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£27.14
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£18.52
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£37.30
£37.98
Scroll to top
