BT.com
Wishlist
Targus Bluetooth 4.0 Micro USB Adapter for Laptops
Targus Bluetooth 4.0 Micro USB...
£12.87
£12.87
Add to wishlist
Delivery
Standard Due date unavailable
Targus USB Bluetooth® 4.0 Adapter brings Bluetooth compatibility to your desktop PC or laptop enabling you to work with Bluetooth enabled peripherals. Supporting the latest Version 4.0 specification, it offers ultra-low power consumption with support for Bluetooth Low Energy. Fast data transfer rates of up to 3Mbps help speed up file and data movement between devices, synchronize contacts and calendar information with your smart phone, wirelessly print and even connect to the internet or a network via your mobile phone. Capable of operating within a range of up to 10m, you can now connect to multiple Bluetooth enabled devices, such as a keyboard, mouse and printer to create a truly wire-free environment.
Targus Bluetooth 4.0 Micro USB Adapter for Laptops - network adapter
Network adapter
External
Interface (Bus) Type
USB
1.8 cm x 1.4 cm x 0.7 cm
2.5 g
Europe
Bluetooth 4.0
Connection / user qty: 7
Bluetooth 1.1, Bluetooth 1.2, Bluetooth 2.0, Bluetooth 2.1
Microsoft Windows Vista / XP / 7 / 8
2 years warranty
Network adapter
External
USB
Europe
Wireless
Bluetooth 4.0
Max Range Indoors
10 m
USB powered, plastic housing
Aerial
Antenna
Internal
1 x USB - 4 pin USB Type A
1.8 cm
1.4 cm
0.7 cm
2.5 g
Scroll to top
