BT.com
Wishlist
Targus 7-Port USB Desktop Hub - Black
Targus 7-Port USB Desktop Hub -...
£27.51
4 in stock
£27.51
Add to wishlist
Delivery
Standard 3-5 working days
Get the maximum performance from your USB peripheral devices via this USB 2.0 desktop hub, offering support for up to 7 USB devices in a compact flexible unit. This hub features seven 2.0 ports, packaged in an attractive enclosure. It is ideal for your desktop set-up, allowing for easy connection and data transfer of up to 480Mbps for seven USB devices connected to your USB enabled computer. Over current protection and plug and play functionality ensure this hub will not let you down. This hub is compatible with both PC and Mac.
Targus 7-Port USB Desktop Hub - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x USB 2.0
USB powered
USB 2.0
7.6 cm x 6.9 cm x 3.1 cm
82 g
2 years warranty
Bundled Services
2 years warranty
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
7 x USB 2.0
USB powered
USB 2.0
7 x USB 2.0 - Type A , 1 x USB 2.0 - Type A
External power adapter
7.6 cm
6.9 cm
3.1 cm
82 g
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.80
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.53
£15.73
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.21
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.64
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.15
£42.31
Scroll to top
