BT.com
Wishlist
Targus 7-Port USB 3.0 Combo Hub - Black
Targus 7-Port USB 3.0 Combo Hub -...
£80.80
£80.80
Add to wishlist
Delivery
Standard Due date unavailable
A sleek design for a new breed of USB products, that is what Targus offers with this new hub with a total of 7 ports. Ever increasing number of USB 3.0 devices are being manufactured that need to be connected. What better way than to simplify all that by using a hub that combines 3 x USB 3.0 ports with an additional 4 x USB 2.0 ports. HD media files, large files, and other resource-intensive operations can be handled at Super Speeds up to 5 Mbps. The new 7-port hub will expand your USB capability to allow you the simultaneous connection of up to 7 devices that would otherwise clutter your desk with cables and occupy all of your desktop or laptop's USB ports.
Targus 7-Port USB 3.0 Combo Hub - hub - 7 ports - desktop
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
3 x SuperSpeed USB 3.0 + 4 x USB 2.0
Plastic housing
USB 2.0, USB 3.0
10.9 cm x 7.5 cm x 2.4 cm
91 g
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP / 7 / 8
2 years warranty
Bundled Services
2 years warranty
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
Plastic housing
USB 2.0, USB 3.0
3 x USB 3.0 - Type A , 4 x USB 2.0 - Type A
External power adapter
1 x USB cable
Plug and Play
10.9 cm
7.5 cm
2.4 cm
91 g
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.80
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.53
£15.73
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.21
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.64
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.15
£42.31
Scroll to top
