BT.com
Wishlist
Targus 4-Port Mobile USB Hub
Delivery
Standard Due date unavailable
The Targus 4-Port Mobile USB Hub is convenient for those who travel with their laptops and would like to connect to their peripherals via a USB port. Expand one USB port to four high-speed ports to connect and charge your iPod/MP3 player, smartphone or peripherals through the laptop. The USB cable never gets lost and stores inside of the hub for easy travel. Both compact and sleek, the Targus hub is portable and easy-to-use; simply plug and play.
Targus 4-Port Mobile USB Hub - hub
Hub
Subtype
USB
8.7 cm x 3.8 cm x 1.4 cm
30 g
Grey, black
Apple MacOS X 10.2 or later, Microsoft Windows 2000/XP/Vista/7
Europe
2 years warranty
Bundled Services
2 years warranty
Hub
Enclosure Type
Desktop
Subtype
USB
4 x USB 2.0 - Type A , 1 x USB - Type B
Grey, black
1 x USB cable
RoHS
Europe
Additional Requirements
USB port
8.7 cm
3.8 cm
1.4 cm
30 g
Accessories
C2G 2m USB 2.0 A/B Cable - Black
Quicklinx: 63M8 | In Stock
£3.80
C2G 5m USB 2.0 A/B Cable - Black
Quicklinx: 63MW | In Stock
£5.30
C2G 2-Port USB 2.0 Manual Switch
Quicklinx: 6874 | In Stock
£22.53
£15.73
C2G 4-Port USB 2.0 Aluminum Hub
Quicklinx: 7BB4 | In Stock
£30.21
C2G 12m USB 2.0 A/A Active Extension Cable
Quicklinx: 7BB8 | In Stock
£20.64
C2G USB Superbooster Extender Kit
Quicklinx: 7H7B | In Stock
£40.15
£42.31
Scroll to top
