BT.com
Wishlist
Tandberg LTO-4 HH External drive kit black SCSI
Delivery
Standard Due date unavailable
LTO has been known as the enterprise-class technology of choice for medium to large size businesses and in medium and large size libraries. Tandberg Data's LTO-4 Half-Height (HH) drive brings enterprise-level performance to small and medium businesses at an affordable price. The Tandberg LTO-4 HH drive features high capacity and a dynamically variable adaptive tape speed to match host data rate to match host transfer speeds, providing maximum data throughput and reduced backup and restore times.
The Tandberg LTO Half-Height (HH) drives offer one of the industry's fastest transfer rates with high capacity to minimize backup times, Its compact size, provides simple and easy integration into all servers and workstation. The LTO technology makes it easy for users to standardize on a tape technology that meets data capacity requirements and ensures futures growth potential.
Tandberg LTO-4 HH - tape drive - LTO Ultrium - SCSI
Tape drive
Recording Standard
LTO Ultrium 4
Enclosure Type
External
Interface Type
SCSI LVD
14.5 cm x 20.6 cm x 4.1 cm
1.45 kg
Storage Removable
LTO Ultrium
Storage Removable Capacity
800 GB (native) / 1.6 TB (compressed)
Supported Tape Cartridges (Read and Write)
Ultrium 3, Ultrium 4
Data Transfer Rate (native)
80 MBps (288 GBph)
Data Transfer Rate (compressed)
160 MBps (576 GBph)
Microsoft Certification
Works with Windows Vista
3 years warranty
Tape drive - LTO Ultrium
Recording Standard
LTO Ultrium 4
Enclosure Type
External
Interface Type
SCSI LVD
Built-in Devices
Led panel
Enclosure Colour
14.5 cm
20.6 cm
4.1 cm
1.45 kg
Storage Removable
LTO Ultrium
Recording Standard
80 MBps (288 GBph)
160 MBps (576 GBph)
Average Seek / Access Time
70 sec
Buffer Size
128 MB
1 x Ultra320 SCSI LVD (input) - 68 pin HD D-Sub (HD-68) , 1 x Ultra320 SCSI LVD (output) - 68 pin HD D-Sub (HD-68)
Media Included Qty
1
1 x SCSI cable
MTBF
250,000 hour(s)
Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
TUV, VCCI, C-Tick, BSMI, EN 60950, NOM, RRL, IEC 60950, CSA 22.2 No. 60950, CB, FCC CFR47 Part 15, AES-256
Power supply
20 Watt
Software Included
Symantec Backup Exec QuickStart
Limited warranty - replacement - 3 years - shipment - response time: 2 business days
10 °C
20 - 80%
Scroll to top
