BT.com
Wishlist
tado Smart Thermostat intelligent climate control system
tado Smart Thermostat intelligent...
£186.34
£186.34
Add to wishlist
Delivery
Standard Due date unavailable
The Smart Thermostat that uses your phone's location to cut your heating bill.
It's time for smarter heating
The majority of your energy costs stem from your heating system, which is running on outdated technology. Now there's a smart solution: tado°. It helps you save energy and will pay for itself in under a year.
Your personal heating assistant... ...makes sure it's always warm when you get home. While you're out, tado° cuts your heating costs - automatically and around the clock. Over time tado° gets to know your home and learns how to heat it up most efficiently. It also uses weather forecasts and lets the sun warm your home when possible. So just relax and let tado° work for you.
Saving when no one's home
tado° makes sure that no energy is wasted when you're out and about. It carefully reduces the temperature to an optimal level, keeping in mind how to pre-warm the home most efficiently for your return. This cuts overall heating costs by up to 31%. In the UK that's a whopping £1000 in just 5 years.
tado° gets to know your building
Do all buildings behave the same when it comes to heating? Far from it! Insulation, room sizes, windows and heating types all significantly affect how a building heats up. That's why tado° starts working out the most efficient way to heat your home from the moment you first turn it on.
tado° checks the weather forecast
tado° constantly monitors the weather forecast so it knows when it's best to let the sun warm your home. This saves more energy and keeps your room temperature at a comfortable level. Do you have underfloor heating? Then this is definitely a feature for you!
See how you save
Our new report shows you when your heating was on and what triggered it. You can also see the effect of the sun and your hot water activity. Want to know how much you spent on heating today? Our mobile app will tell you with just a swipe of your finger.
Monitor and control your heating from anywhere
Keep an eye on how tado° is heating your home - wherever you are. Take control if you like. Change the settings on the go or switch to manual mode - everything's just a few clicks away with our mobile app for Android and iOS phones and tablets.
Works with 95% of all heating systems
So you live in a multi- or single-family house and have your own boiler? That's great! Because tado° works with 95% of all heating systems, including gas or oil boilers, heat pumps, electrical systems and many more. It also supports both radiators and underfloor heating. Check your heating now or just call us if you're unsure and we'll find out together.
Unbox. Install. Relax.
It's time for smarter heating. Our 30-day money back guarantee lets you return tado° free of charge in case you're not completely satisfied. So why delay? Winter is coming!
tado° takes care
Did your heating stop working over the summer without you noticing? Does the circulation pump need to be replaced? Now you can relax when the heating season starts. tado° Care is a free service to keep your heating system running smoothly and offer immediate help in case of malfunctions.
tado° Care at a glance:
Remote boiler check
Boiler error code notifications
Do-it-yourself repair instructions
Phone support
Referral for professional repairs
Scroll to top
