BT.com
Wishlist
tado Smart Heating Extension Box
Delivery
Standard Due date unavailable
The tado° Extension Kit connects your tado° Smart Thermostat to your boiler if there is no cable for a thermostat from your boiler to your living room. The tado° Extension Kit ensures that hot water is only prepared when it's needed. It also keeps bacteria like Legionella away by triggering the necessary heating cycles.
tado° Extension Kit - central controller
Central controller
Wireless
Frequency Band
868 MHz
Matt white
15 cm x 2.8 cm x 10.2 cm
Central controller
Wireless
Frequency Band
868 MHz
4 wire connection
Aerial
Internal
Matt white
Encryption Algorithm
256-bit SSL, TLS 1.2
Nominal Voltage
AC 120/230 V
RoHS 2011/65/EU, EMC 2004/108/EC, LVD 2014/35/EU, R&TTE Directive 1999/5/EC
15 cm
2.8 cm
10.2 cm
210 g
Scroll to top
