BT.com
Wishlist
Synology RXD1215sas/24TB-RED PRO 12 Bay
Synology RXD1215sas/24TB-RED PRO 12...
£3,861.46
£3,861.46
Add to wishlist
Delivery
Standard Due date unavailable
Featuring a high-availability design, next-generation snapshot technology, and massive scalability up to 180 drives, RXD1215sas delivers the secure, reliable, and superior performance storage solution for enterprises seeking business continuity and point-in-time data recovery.
Synology RackStation RXD1215SAS - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
24 TB
SAS
12 (installed) / 12 (max)
Supported Drives
SAS
Storage Controller
RAID ( SAS ) - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 2 TB HDD - hot-swap
AC 120/230 V - 50 - 60 Hz
Power Redundancy
43 cm x 69.2 cm x 8.8 cm
18 kg
5 years warranty
Hard drive array
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SAS
Storage
24 TB
HDD Array External Interface
SAS
Storage Controller
RAID
Interface Type
SAS
Max Storage Devices Qty
12
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
12 x 2 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
2 x SAS ( input ) , 2 x SAS ( output )
Built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
248 Watt
Power Provided
500 Watt
43 cm
69.2 cm
8.8 cm
18 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Scroll to top
