BT.com
Wishlist
Synology RX410 4-Bay Expansion Unit for RS810+ & RS810RP+
Delivery
Standard Due date unavailable
Synology RX410 delivers an effortless solution for volume expansion and data backup for Synology RackStation RS810+/RS810RP+. The RX410 seamlessly scales up the storage capacity of the Synology RS810+/RS810RP+ by an additional 4 hard drives on-the-fly when connected directly to the Synology RS810+/RS810RP+.
Synology RX410 - hard drive array
Hard drive array
Enclosure Type
Rack-mountable
SATA 3Gb/s
0 (installed) / 4 (max)
Supported Drives
SATA-300
Storage Controller
RAID (SATA 3Gb/s) - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare
Hard Drive
0 HDD - hot-swap
AC 120/230 V - 50/60 Hz
45.7 cm x 43.1 cm x 4.4 cm
7.1 kg
5 years warranty
RackStation RS810+, RS810RP+, RS812, RS812+, RS812RP+
Hard drive array
Enclosure Type
Rack-mountable
Chassis
0
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage
HDD Array External Interface
SATA 3Gb/s
Storage Controller
RAID
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare
Hard Drive
HDD - hot-swap
0
Expansion Bays
4 (total) / 4 (free) x hot-swap
1 x SATA 3Gb/s - 7 pin external Serial ATA
2 x eSATA cable
Mounting Kit
Included
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
45.7 cm
43.1 cm
4.4 cm
7.1 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Synology RackStation RS810+, RS810RP+, RS812, RS812+, RS812RP+
Scroll to top
