BT.com
Wishlist
Synology RX1217RP/120TB (12x10TB Seagate IronWolf Pro) 2U 12 bay
Synology RX1217RP/120TB (12x10TB...
£6,618.73
£6,618.73
Add to wishlist
Delivery
Standard Due date unavailable
Synology Expansion Unit RX1217RP delivers an effortless solution for data volume expansion and data backup. With additional 12 drive bays, RX1217RP seamlessly expands the storage capacity of the connected Synology NAS on-the-fly.
Synology RX1217RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
12 (installed) / 12 (max)
Supported Drives
SATA-600
Hard Drive
12 x 10 TB HDD SATA 6Gb/s - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
43.05 cm x 69.6 cm x 8.8 cm
13.4 kg
5 years warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Hard Drive
HDD - hot-swap
12 x 10 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x InfiniBand
1 x InfiniBand cable
FCC Class A certified, RoHS, BSMI Class A
Rail kit
2 x internal power supply
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
43.05 cm
69.6 cm
8.8 cm
13.4 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Other bundles
Synology RX1217RP/120TB (12x10TB Seagate IronWolf Pro)...
£6,618.73
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.19
£6,621.92
Scroll to top
