BT.com
Wishlist
Synology RX1214RP 72TB (12 x 6TB WD RED PRO) 12 Bay NAS Solution
Delivery
Standard Due date unavailable
Synology RX1214RP delivers an effortless solution for volume expansion and data backup for Synology RackStation RS2414RP+. The /RX1214RP seamlessly scales up the storage capacity of the Synology RS2414RP+ by an additional 12 hard drives on-the-fly when connected directly to an expansion cable.
Synology RX1214RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
72 TB
12 (installed) / 12 (max)
Supported Drives
SATA-600
Hard Drive
12 x 6 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
44.5 cm x 57 cm x 8.8 cm
5 years warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Storage
72 TB
Hard Drive
HDD - hot-swap
12 x 6 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x InfiniBand
Built-in 4 cooling fans
1 x InfiniBand cable
FCC Class A certified, RoHS
TAA Compliant
Rail kit
2 x internal power supply
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
121 Watt
Power Provided
400 Watt
44.5 cm
57 cm
8.8 cm
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
42.2 dBA
Scroll to top
