BT.com
Wishlist
Synology RS816 12TB (4x3TB WD RED HDD) 4 Bay Rack-Mount NAS
Synology RS816 12TB (4x3TB WD RED...
£982.06
£982.06
Add to wishlist
Delivery
Standard Due date unavailable
Compact, robust, and scalable, RS816 comes with compelling and crucial features that growing businesses are looking for in a rackmount file server. With the dual LAN failover support, this 1U 4-bay rackmount NAS ensures continual availability, promising steadily growing success at a minimum cost.
Synology RackStation RS816 - NAS server - 12 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
12 TB
Max Supported Capacity
40 TB
4 (installed) / 4 (max)
43.05 cm x 29.55 cm x 4.4 cm
1 x Marvell ARMADA 88F6820 1.8 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 3 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
16
RAM
1 GB
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
12 TB
40 TB
43.05 cm
29.55 cm
4.4 cm
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 3 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
L2TP, iSCSI
Remote Management Protocol
SNMP, Telnet, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), antivirus analysis, Access Control List (ACL) support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED
Security DVR
16
Compression Format
MJPEG, H.264
Image Resolution
1920x1080, 2048x1536, 1280x800, 2591x1944
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
Wake on LAN, built-in 3 cooling fans, scheduled power on/off
FCC Class A certified, RoHS, BSMI Class A
Internal power supply
27.9 Watt
Power Provided
150 Watt
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
28.9 dBA
Other bundles
Synology RS816 12TB (4x3TB WD RED HDD) 4 Bay Rack-Mount...
£982.06
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.19
£985.25
Scroll to top
