BT.com
Wishlist
Synology RS815RP+/32TB-RED 4 Bay Rackmount NAS
Delivery
Standard Due date unavailable
Featuring a quad-core processor and AES-NI hardware encryption engine, RS815RP+ delivers the superior performance which is essential for business's data transmission needs. The ability to expand to 6 GB DDR3 RAM and scale storage up to 8 drives with Synology Expansion Unit RX415 gives your business the agility to meet evolving workload demands.
Synology RackStation RS815RP+ - NAS server - 32 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
32 TB
Max Supported Capacity
32 TB
4 (installed) / 4 (max)
43.05 cm x 59.18 cm x 4.4 cm
9.36 kg
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / eSATA - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 1 hot spare
Hard Drive
4 x 8 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Power Redundancy
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
32 TB
32 TB
43.05 cm
59.18 cm
4.4 cm
9.36 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s / eSATA
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 1 hot spare
Hard Drive
HDD - hot-swap
4 x 8 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, PPTP, L2TP, PPPoE, iSCSI, LPR/LPD, SMTP, FTP, DNS, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), DNS, File Level Security (ACLs), DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, print server, IPv6 support, High Availability, firmware upgradable, MySQL server, backup server, download client, file sharing, event log, Access Control List (ACL) support, RADIUS support, SSH support, iTunes server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DNS server, DLNA Media Server, eMule client, e-mail notification, cloud backup, VPN Server, anti-virus protection
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
40
Compression Format
MJPEG, H.264
Image Resolution
1920x1080, 2048x1536, 1280x800, 2591x1944
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
Wake on LAN, built-in 3 cooling fans, scheduled power on/off
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
45.88 Watt
Power Provided
250 Watt
Software Included
Synology Assistant, McAfee AntiVirus
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
52.8 dBA
Scroll to top
