BT.com
Wishlist
Synology RS815RP+ 24TB (4 x 6TB WD RED PRO) 4 Bay NAS Solution
Synology RS815RP+ 24TB (4 x 6TB WD...
£2,269.32
£2,269.32
Add to wishlist
Delivery
Standard Due date unavailable
Featuring a quad-core processor and AES-NI hardware encryption engine, RS815RP+ delivers the superior performance which is essential for business's data transmission needs. The ability to expand to 6 GB DDR3 RAM and scale storage up to 8 drives with Synology Expansion Unit RX415 gives your business the agility to meet evolving workload demands.
Synology RackStation RS815RP+ - NAS server - 24 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
Total Storage Capacity
24 TB
Max Supported Capacity
24 TB
4 (installed) / 4 (max)
43.05 cm x 59.18 cm x 4.4 cm
9.36 kg
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
Hard Drive
4 x 6 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Power Redundancy
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 1U
24 TB
24 TB
43.05 cm
59.18 cm
4.4 cm
9.36 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
RAM
2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
HDD - hot-swap
4 x 6 TB
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, SMTP, FTP, DNS, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
DNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, antivirus analysis, High Availability, MySQL server, backup server, file sharing, Access Control List (ACL) support, RADIUS support, SSH support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DNS server, DLNA Media Server, eMule client
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
40
Expansion Bays
4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x eSATA , 1 x serial (management) - DB-9
Wake on LAN, built-in 3 cooling fans
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
45.88 Watt
Power Provided
250 Watt
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
52.8 dBA
Hard Drives - Hard Drives
Synology RS815RP+ 24TB (4 x 6TB WD RED PRO) 4 Bay NAS...
£2,269.32
Save on 4x6TB WD Red with 4bay NAS
Save £31.96
£2,958.31
£2,269.32
Save on 4x4TB WD Red with 4bay NAS
Save £24.00
£2,705.30
£2,269.32
Save 4x3TB WD Red with 4bay NAS
Save £15.98
£2,626.39
£2,269.32
Save 4x2TB WD Red with 4bay NAS
Save £12.00
£2,548.44
Other bundles
£2,269.32
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.19
£2,272.51
Scroll to top
