BT.com
Wishlist
Synology RS3617xs/120TB (12x10TB Seagate IronWolf Pro) 2U 12 bay
Delivery
Standard Due date unavailable
Designed for large-scale businesses, RS3617xs provides high-performance throughput with comprehensive business applications. RS3617xs allows you to centralize storage, simplify data management, and deploy virtualization solutions with minimal time required for setup and maintenance.
Synology RackStation RS3617xs - NAS server - 120 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
120 TB
Max Supported Capacity
96 TB
12 (installed) / 12 (max)
44.5 cm x 57 cm x 8.8 cm
1 x Intel Xeon E3-1230V2 3.3 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 10 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
75
RAM
4 GB
5 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
120 TB
96 TB
44.5 cm
57 cm
8.8 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
12 x 10 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
L2TP, iSCSI
Remote Management Protocol
SNMP, Telnet, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Network File System (NFS), Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), antivirus analysis, Access Control List (ACL) support, iTunes server, UPnP Media Server, surveillance station, DLNA Media Server, cloud backup, VPN Server
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED
Security DVR
75
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
2 (total) / 2 (free) x PCI Express 3.0 x8
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9 , 2 x InfiniBand
Wake on LAN, built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
Internal power supply
Installed Qty
1
Max Supported Qty
1
Power Provided
500 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Scroll to top
