BT.com
Wishlist
Synology RS2416+ 120TB (12x10TB Seagate HDD) 12 Bay Rack-Mount NAS
Delivery
Standard Due date unavailable
Next-generation data protection and integrity
When dealing with large-scale data storage, businesses require a solution that offers reliable backup and prevents file corruption. With support for the next-generation Btrfs file system, RS2416+/RS2416RP+ ensures information is stored with a high level of data integrity, while providing flexible and efficient data protection tools.
Fast and efficient snapshots
Snapshots preserve the history of a shared folder allowing you to save up to 2561 backup copies for point-in-time recovery. Snapshots can be automatically captured up to every 5 minutes, without noticeably impacting system performance.
Metadata mirroring and survivability
Btrfs file system stores two copies of critical metadata on a volume, improving the availability and survivability of your business’s important data.
Corruption detection and correction
By generating checksums for files and metadata, the system can automatically detect and attempt to repair corrupted data or report errors to the administrator.
Customizable quotas for shared folders
With Btrfs, you can specify a storage limit for each shared folder, making it possible to precisely control space consumption when multiple teams or departments save files on the same Synology NAS server.
Synology RackStation RS2416+ - NAS server - 120 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
120 TB
12 (installed) / 12 (max)
43 cm x 69.2 cm x 8.8 cm
1 x Intel Atom C2358 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 10 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
120 TB
43 cm
69.2 cm
8.8 cm
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap - 3.5"
12 x 10 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, iSCSI, FTP, NFS
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
LDAP support, wake on LAN (WOL), Syslog support, antivirus analysis, video server, Access Control List (ACL) support, e-mail server, surveillance station, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
Security DVR
40
Compression Format
MJPEG, H.264
Image Resolution
1280x720, 1920x1080, 2048x1536, 2591x1944
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x management
Built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Internal power supply
Power Provided
500 Watt
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
41.5 dBA
Scroll to top
