BT.com
Wishlist
Synology RS18016xs+/24TB-REDPRO 12 Bay NAS
Delivery
Standard Due date unavailable
RS18016xs+ delivers superior performance at over 3,900 MB/s throughput and 348,000 IOPS under RAID 5 configuration. RS18016xs+ is equipped with 8GB ECC RAM, expandable to 32 GB if needed, so enterprises can guarantee data accuracy, as well as superior performance for the mission-critical tasks of the business.
RS18016xs+ supports a combination of hard drives and read/write-optimized SSD cache, boosting throughput efficiently while minimizing cost per gigabyte. With full SSD cache reading and writing support, RS18016xs+ offers a significant reduction in I/O latency without crippling your budget. With only a small upfront investment, businesses can benefit from significant enhancement in server performance.
In addition to the default 4 Gigabit ports, RS18016xs+ includes two PCIe 3.0 x8 slots, allowing installation of two dual-port 10GbE network interface cards for maximized bandwidth, bringing you the superior performance that data-intensive applications demand of your storage system. With native SAS & SATA III 6Gb/s interface support, RS18016xs+ ensures the optimum data process under heavy system loading.
Synology RackStation RS18016xs+ - NAS server - 24 TB
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
Total Storage Capacity
24 TB
Max Supported Capacity
96 TB
12 (installed) / 12 (max)
43 cm x 69.2 cm x 8.8 cm
14.5 kg
1 x Intel Xeon E3-1230V2 3.3 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s / SAS - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
12 x 2 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
90
RAM
8 GB
Power Redundancy
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
5 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
Enclosure Type
Rack-mountable - 2U
24 TB
96 TB
43 cm
69.2 cm
8.8 cm
14.5 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
8 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s / SAS
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
12 x 2 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
PPTP, L2TP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), antivirus analysis, IP address filtering, MySQL server, web server, backup server, download client, file sharing, Access Control List (ACL) support, iTunes server, DHCP server, FTP server, e-mail server, surveillance station, DLNA Media Server, VPN Server
Encryption Algorithm
AES, SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
90
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
4 (total) / 2 (free) x DIMM 240-pin , 2 x PCI Express 3.0 x8
2 x USB 2.0 - Type A , 2 x SAS , 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 1 x serial RS-232 (management) - DB-9
Built-in 4 cooling fans
FCC Class A certified, RoHS, BSMI Class A
TAA Compliant
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
106.54 Watt
Power Provided
500 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
45.1 dBA
Scroll to top
