BT.com
Wishlist
Synology DX513/40TB-RED 5 Bay NAS
£1,734.56
£1,734.56
Add to wishlist
Delivery
Standard 1-3 working days
Synology DX513 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX513 seamlessly scales up the storage capacity of the DiskStation by additional 5 hard drives on-the-fly when connected directly to an expansion cable.
Synology DX513 - storage enclosure
Storage enclosure
5 (installed) / 5 (max)
Supported Drives
SATA-600
Hard Drive
5 x 8 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
24.8 cm x 23.3 cm x 15.7 cm
3.91 kg
3 years warranty
Storage enclosure
Chassis
5
Supported Devices / Modules Qty
5
Supported Drives
SATA-600
Hard Drive
HDD - hot-swap
5 x 8 TB
Expansion Bays
5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
1 x eSATA
Built-in 2 cooling fans
1 x eSATA cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
45.1 Watt
24.8 cm
23.3 cm
15.7 cm
3.91 kg
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Sound Emission
21.5 dBA
Scroll to top
