BT.com
Wishlist
Synology DX213 2-Bay NAS Expansion Unit
Delivery
Standard Due date unavailable
DiskStation DX213
Synology® DX213 delivers an effortless solution for volume expansion and data backup for selected Synology DiskStation models. The DX213 seamlessly scales up the storage capacity of the DiskStation by additional 2 hard drives on-the-fly when connected directly to an expansion cable.
Volume Expansion & Backup
When running out of hard drive capacity on the Synology DiskStation, Synology DX213 provides an easy way to immediately scale capacity by additional 2 hard drives. The RAID volume on the Synology DiskStation can be expanded directly without having to reformat the existing hard drives, ensuring the Synology DiskStation continues its service during the capacity expansion.
Synology DX213 can be used as a dedicated local backup solution for the Synology DiskStation. When created as a separate volume, the Synology DX213 provides a great backup solution to its local hard disks in case of system failure.
Reliable Plug-n-use Design
The Synology DX213 is connected to the Synology DiskStation using an expansion cable with custom-designed connectors on both ends, ensuring a reliable connection and maximum throughput. The 3.0 Gb/sec connection speed allows the hard drives in the connected Synology DX213 to operate as the internal ones of Synology DiskStation.
Green & Easy to Manage
The HDD hibernation and system hibernation can be manually configured to take effect automatically when the system has been inactive for a period of time. This not only saves energy but also extends the lifespan of the hard disk. The DX213 will also smartly power on/off with the attached DiskStation, so no user intervention is needed to keep this system running smartly and efficiently.
Technical Specifications
  • Internal HDD/SSD 3.5" or 2.5" SATA(II) X 2 (hard drives not included)
  • Expansion Port X 1
  • Volume Type Synology Hybrid RAID, Basic, JBOD, RAID 0, RAID 1
  • Size (HxWxD) 165mm X 100mm X 225.5mm
  • Weight 0.87KG
  • System Fan 92x92mm
  • Noise Level1 19dB(A)
  • Power Recovery Sync with the connected DiskStation (Default Mode)
  • AC Input Power Voltage 100V to 240V
  • Power Frequency 50Hz to 60Hz, Single Phase
  • Operating Temperature 5°C to 35°C (40°F to 95°F)
  • Storage Temperature -10°C to 70°C (15°F to 155°F)
  • Relative Humidity 5% to 95%RH
  • Maximum Operating Altitude 10,000feet
  • Power Consumption2 21W (Access), 6W (HDD Hibernation)
  • Supported Models3 DS710+, DS712+, DS1010+, DS1511+, DS1512+, DS1812+ DS112, DS112+, DS212+, DS213+, DS412+, DS413 (use as independent volume)
Synology DX213 - hard drive array
Hard drive array
Total Array Capacity
0 GB
2 (max)
Storage Controller
RAID (SATA 3Gb/s) - RAID 0, 1, JBOD
Hard Drive
No HDD
AC 120/230 V - 50 - 60 Hz
10 cm x 22.55 cm x 16.5 cm
0.87 kg
2 years warranty
Disk Station DS1010+, DS1511+, DS1512+, DS1812+, DS710+, DS712+
Hard drive array
Chassis
Supported Devices / Modules Qty
2
Storage
0 GB
Storage Controller
RAID - integrated
Channel Qty
2
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) x internal - 2.5" / 3.5" shared
Mounting Kit
Included
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
External power adapter
21 Watt
10 cm
22.55 cm
16.5 cm
0.87 kg
5 °C
35 °C
5 - 95%
Sound Emission
19 dBA
Synology Disk Station DS1010+, DS1511+, DS1512+, DS1812+, DS710+, DS712+
Accessories
C2G 2m External Serial ATA Cable
Quicklinx: 6878 | In Stock
£9.57
Resources
The following resources are available for the Synology DX213 2-Bay NAS Expansion Unit
Scroll to top
