BT.com
Wishlist
Synology DX1215 24TB-RED Pro Expansion Unit
Synology DX1215 24TB-RED Pro...
£933.79
£933.79
Add to wishlist
Delivery
Standard Due date unavailable
Synology DX1215 delivers an effortless volume expansion and data backup solution for selected Synology DiskStation servers by providing an additional 12 drive slots with SATA III 6Gb/s interface support.
Synology DX1215 - hard drive array
Hard drive array
Total Array Capacity
24 TB
Max Supported Capacity
72 TB
InfiniBand
12 (installed) / 12 (max)
Supported Drives
SATA-600
Storage Controller
(SATA 6Gb/s)
Hard Drive
12 x 2 TB HDD SATA 6Gb/s - hot-swap
AC 120/230 V - 50/60 Hz
27 cm x 30 cm x 34 cm
9.02 kg
5 years warranty
Hard drive array
Chassis
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600
Storage
24 TB
72 TB
HDD Array External Interface
InfiniBand
Storage Controller
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
Hard Drive
HDD - hot-swap
12 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
12 (total) / 0 (free) x hot-swap - 3.5"
1 x InfiniBand
1 x InfiniBand cable
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
500 Watt
27 cm
30 cm
34 cm
9.02 kg
Limited warranty - 5 years
5 °C
35 °C
5 - 95%
Sound Emission
27.2 dBA
Other bundles
£933.79
Save 50% On This 1m SATA Cable When Bought With This Item
Save £3.22
£937.01
Scroll to top
