BT.com
Wishlist
Synology DS3615xs 24TB (12 x 2TB WD Red Pro) 12 Bay Desktop NAS
Delivery
Standard Due date unavailable
Synology DiskStation DS3615xs provides a premium-performance NAS solution for large scale businesses that require an efficient way to centralize data protection, simplify data management, deploy virtualization solutions, and rapidly expand storage capacity with minimal time spent on setup and maintenance.
Synology Disk Station DS3615xs - NAS server - 24 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
24 TB
Max Supported Capacity
72 TB
12 (installed) / 12 (max)
30 cm x 34 cm x 27 cm
9.8 kg
1 x Intel Core i3 4130 3.4 GHz (Dual-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare, 1 hot spare
Hard Drive
12 x 2 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
75
RAM
4 GB
Storage Operating System
Synology DiskStation Manager
5 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
24 TB
72 TB
30 cm
34 cm
27 cm
9.8 kg
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
4 GB (installed) / 32 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare, RAID 1 hot spare
Hard Drive
HDD - hot-swap - 3.5"
12 x 2 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Buffer Size
64 MB
Network / Transport Protocol
L2TP, iSCSI, LPR/LPD, SMTP, FTP, POP3, IMAP
Remote Management Protocol
Telnet, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, wake on LAN (WOL), Syslog support, print server, download client, Access Control List (ACL) support, RADIUS support, iTunes server, BitTorrent Client, e-mail server, bandwidth control, surveillance station, DNS server, eMule client, VPN Server
Encryption Algorithm
SSL, TLS
Security DVR
75
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x PCI Express x8
2 x USB 3.0 - Type A , 4 x Ethernet 1000Base-T - RJ-45 , 1 x serial (management) - DB-9
2 x network cable
Built-in 2 cooling fans, Google Cloud Print
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
500 Watt
Limited warranty - 5 years
5 °C
35 °C
5 - 95% (non-condensing)
Sound Emission
27.4 dBA
Scroll to top
