BT.com
Wishlist
Synology DS1815+ 16TB-Red  Desktop NAS
Delivery
Standard Due date unavailable
Featuring a quad-core processor, hardware encryption engine, and flawless software integration, DS1815+ is a powerful, expandable 8-bay NAS server that delivers outstanding speed and accelerated data encryption. Easily scalable, the DS1815+ can be equipped with 6 GB of DDR3 RAM and host 48 TB of raw capacity with two Synology DX513 units.
Synology Disk Station DS1815+ - NAS server - 16 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
16 TB
Max Supported Capacity
48 TB
8 (installed) / 8 (max)
34 cm x 23.3 cm x 15.7 cm
5.29 kg
1 x Intel Atom C2538 2.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s - RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
8 x 2 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
40
RAM
2 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
3 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
16 TB
48 TB
34 cm
23.3 cm
15.7 cm
5.29 kg
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
2 GB (installed) / 6 GB (supported) - DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD
8 x 2 TB
Network / Transport Protocol
TCP/IP, iSCSI, SMTP, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, LDAP support, Syslog support, E-mail alert, print server, firmware upgradable, MySQL server, web server, backup server, file sharing, RADIUS support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, DNS server, DLNA Media Server, eMule client, VPN Server
DLNA CERTIFIED, UPnP
Security DVR
40
Expansion Bays
8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x eSATA
2 x network cable
Wake on LAN, built-in 2 cooling fans
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
Internal power supply
Power Provided
250 Watt
Software Included
Synology Assistant, Synology Data Replicator
Limited warranty - 3 years
5 °C
35 °C
5 - 95%
Scroll to top
