BT.com
Wishlist
Synology DS116 1TB (1 x 1TB WD RED) 1 Bay Desktop NAS
Delivery
Standard Due date unavailable
Synology DiskStation DS116 is a compact 1-bay NAS server with outstanding performance, bringing you a novel way to store, share, stream and synchronize data in your daily life. With comprehensive office and multimedia applications, DS116 is designed to boost up productivity and let you enjoy multimedia content effortlessly. Synology DS116 is also backed with Synology’s 2-year limited warranty.
Synology DS116 is a compact, all-purpose 1- bay NAS with supreme performance, designed to make your daily data storage activities simpler than ever. Equipped with a Marvell ARMADA dual-core CPU and 1GB DDR3 RAM, DS116 delivers high speed performance with over 112.53 MB/s reading speed and over 111.41 MB/s writing speed in a Windows environment. Powered with a hardware encryption engine, the encrypted data transmission performance can reach over 61.13 MB/s reading speed and 46.07 MB/s writing speed, standing out to be one of the best price/performance ratio NAS available today. With built-in floating-point unit support, DS116 speeds up thumbnail generation to yield a refreshing photo viewing experience. The dual USB 3.0 ports on the rear panel can provide high speed data transmission to a large variety of external USB devices, including Wi-Fi dongles, printers, external hard drives and more.
With a variety of software applications, DS116 turns your hard drive into a versatile storage server, which acts not only as your private cloud to access files anywhere, but also as a backup device, online photo album, local copy of your public cloud, 24/7 download portal, and so much more.
Synology Disk Station DS116 - NAS server - 1 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
1 TB
Max Supported Capacity
8 TB
1 (installed) / 1 (max)
7.1 cm x 22.4 cm x 16.6 cm
1 x Marvell ARMADA 385 1.8 GHz (Dual-Core)
Storage Controller
SATA SATA 6Gb/s
Hard Drive
1 x 1 TB
10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
16
RAM
1 GB
Storage Operating System
Synology DiskStation Manager
Microsoft Windows 7 or later, Apple MacOS X 10.10 or later
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
1 TB
8 TB
7.1 cm
22.4 cm
16.6 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Hard Drive
HDD
1 x 1 TB
Spindle Speed
5400 rpm
Network / Transport Protocol
TCP/IP, PPTP, L2TP, iSCSI, LPR/LPD, FTP, POP3, IMAP
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), Calendaring Extensions to WebDAV (CalDAV)
Firewall protection, hardware encryption, LDAP support, wake on LAN (WOL), print server, IP address filtering, download client, anti-malware protection, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, RADIUS support, iTunes server, Samba support, FTP server, BitTorrent Client, e-mail server, UPnP Media Server, surveillance station, PXE support, DLNA Media Server, e-mail notification, cloud backup, VPN Server, SFTP client, anti-virus protection
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Security DVR
16
Compression Format
MJPEG, H.264
Image Resolution
1920x1080, 2048x1536, 1280x800, 2591x1944
Expansion Bays
1 (total) / 0 (free) x internal - 3.5"
1 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
1 x network cable
Security lock slot (cable lock sold separately), built-in cooling fan, hardware encryption
FCC Class B certified, RoHS, BSMI Class B
External power adapter
Power Provided
36 Watt
Software Included
Synology Assistant
5 °C
5 - 95%
Sound Emission
16.4 dBA
Scroll to top
