BT.com
Wishlist
Synology DiskStation DS213 2-Bay NAS Server
Delivery
Standard Due date unavailable
Synology® DiskStation DS213 is a feature-rich 2-bay NAS server for workgroups and offices, specifically designed for users who need to share and protect data cost-effectively, while increasing productivity with comprehensive office applications.
Optimal Price/Performance Ratio
Synology DS213 delivers an average 108.23 MB/sec reading speed under RAID 1 configuration in a Windows® environment, and 65.41 MB/sec writing1. DiskStation DS213 provides a reliable solution for data sharing with an easy to use interface, and comprehensive office applications, including a complete backup solution making it one of the best values in 2-bay NAS devices available today.
Coming with USB 3.0 support which offers transmission speeds of up to 5 Gbps, namely 10 times faster than USB 2.0, DS213 takes less time for data transfer for external hard drives and consumes less power. In addition, hot-swappable drives make it easier for maintenance and hard drive replacement.
Effective Backup Solutions
Synology DS213 offers a centralized backup target to consolidate fragmented and unstructured data across a network. PC users can back up their data to Synology DS213 using Synology Data Replicator software, and Mac OS X® users enjoy native Apple® Time Machine® integration.
A backup wizard is provided for backing up data from DS213 to another Synology DiskStation or any rsync server via an encrypted connection, or to an external hard drive via USB 3.0 connection. The wizard also makes it easy to back up DiskStation data to the cloud via Amazon S3® or STRATO HiDrive. In addition, users can back up and restore DiskStation shared folders in multiple versions using Synology Time Backup package.
Shared Folder Sync allows users to synchronize a specific folder from Synology DS213 to another DiskStation - a server-to-client backup mechanism that takes place whenever something is changed on the server side. Users will be able to share documents within their local office seamlessly and safely with encrypted connection. When your DiskStation is down, you will be able to have an immediate backup running in no time. You can have your own cloud by using Cloud Station to freely access and sync file across different computers. Cloud Station keep multiple versions of a document in case of accidentally delete or upon any change.
Rich Office Applications
Synology DiskStation DS213 runs on renowned multitasking operating system, the Synology DiskStation Manager (DSM). Offering a comprehensive list of business applications, the DS213 can be customized to run multiple applications of your choice to fulfill the requirement of your business environment. The DS213 replaces several pieces of traditional network hardware with rich features designed specifically for workgroups and offices such as antivirus, video surveillance, webmail, VPN, and LDAP directory services.
Applications are managed in the Package Center, an application portal that hosts applications as ready-to-use packages; to ensure high software integration as well as one-click-installation to eliminate guess work during installation. Additional approved 3rd party PHP web application such as content management, customer relationship management & e-commerce system can be hosted on DS213 by using Web Station with support for PHP/MySQL® web content.
Hassle-free System Installation
Web Assistant is a web-based utility to makes every DiskStation as easy to install as possible. Installation is done inside your existing web browser by setting up all vital system components in few simple steps. Combined with a quick start widget, users can simultaneously tour the DSM operating system and set it up to use right away.
Peace of Mind with Data Encryption
The Synology DS213 is equipped with an encryption engine which offloads the encryption calculation task away from the main CPU, helping to improve file transfer speeds of the DiskStation. Data protection is an important matter for businesses of all sizes. High-end features previously available only on enterprise level hardware are now accessible via Synology DS213 to small and medium-sized businesses. DS213 provides share-level AES 256-bit encryption to aid in the prevention of unauthorized access attempts to the hard drives.
Energy Efficient with Cool and Quiet Design
Synology DS213 is designed with energy efficiency in mind. Not only does it provide a 92x92 mm fan and the smart airflow to keep the system running cool 24/7, its noise dampening design makes it really quiet compared to PC counterparts. The support of Wake on LAN/WAN, multiple scheduled power on/off and hard drive hibernation can further reduce power consumption and operation cost.
All Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology acknowledges the responsibility as a global citizen to continually work to reduce the environmental impact of every product produced.
Technical Specifications
  • CPU Frequency 2.0GHz
  • Hardware Encryption Engine Yes
  • Memory DDR3 512MB
  • Internal HDD/SSD 3.5" or 2.5" SATA(II) X 2 (hard drives not included)
  • Max Internal Capacity 8TB (2X 4TB hard drives) (The actual capacity will differ according to volume types.)
  • Hot Swappable HDD Yes
  • External Storage Interface 1X USB 2.0 port, 2X USB 3.0 ports, 1X SD card slot
  • Size (HxWxD) 165mm X 108mm X 233.2mm
  • Weight 1.25kg
  • LAN 1X Gigabit
  • Wireless Support (wireless dongles not included) Yes
  • Wake on LAN/WAN Yes
  • Noise Level3 19.0 dB(A)
  • AC Input Power Voltage 100V to 240V
  • Power Frequency 50Hz to 60Hz, Single Phase
  • Power Consumption4 18.48 W (Access); 8.28 W (HDD Hibernation)
  • Operating Temperature 5°C to 35°C (40°F to 95°F)
  • Storage Temperature -10°C to 70°C (15°F to 155°F)
  • Relative Humidity 5% to 95%RH
Synology Disk Station DS213 - NAS server - 0 GB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
0 GB
Max Supported Capacity
8 TB
2 (max)
10.8 cm x 23.32 cm x 16.5 cm
1.25 kg
Danish, Hungarian, Czech, Slovenian, Chinese (traditional), Chinese (simplified), Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Russian, Spanish, Dutch, Turkish, Japanese, Korean
1 x 2 GHz
Storage Controller
RAID SATA 3Gb/s - RAID 0, 1, JBOD
Card Reader
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
AC 120/230 V ( 50/60 Hz )
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
0 GB
8 TB
2 (max)
10.8 cm
23.32 cm
16.5 cm
1.25 kg
Processor / Memory
Processors Installed
1 x 2 GHz
Max Supported Qty
1
RAM Installed
512 MB DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card
Network / Transport Protocol
PPTP, PPPoE, LPR/LPD, SMTP, FTP, DHCP, POP3, IMAP, DDNS
Remote Management Protocol
SNMP, Telnet, IPP, HTTP, HTTPS, SSH
Network Services Compatibility
DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, hardware encryption, VPN support, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, print server, IPv6 support, MySQL server, web server, backup server, file sharing, Access Control List (ACL) support, SSH support, iTunes server, DHCP server, Samba support, FTP server, SMS alert, e-mail server, UPnP Media Server, bandwidth control, surveillance station, DLNA Media Server, eMule client, e-mail notification, WebDAV server, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED, UPnP
Expansion Bays
2 (total) / 2 (free) x hot-swap - 2.5" / 3.5"
2 x USB 3.0 - Type A , 1 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Built-in cooling fan, AirPrint, Google Cloud Print
FCC Class B certified, RoHS, BSMI Class B
Mounting kit
TAA Compliant
X external power adapter
18.48 Watt
Software Included
Drivers & Utilities, Synology Assistant, Synology Data Replicator
2 years warranty
Service & Support Details
5 °C
35 °C
5 - 95% (non-condensing)
Sound Emission
19.9 dBA
Resources
The following resources are available for the Synology DiskStation DS213 2-Bay NAS Server
Scroll to top
