Click to visit BT.com
BT.com
Wishlist
Synology 6TB (2 x 3TB WD Red) DS213J 2-Bay Desktop NAS
4.0*
Quicklinx: 8PP2WS00
Mfr#: DS213J/6TB-RED
Synology DiskStation DS213j is a budget-friendly 2-bay NAS server for small offices and home use, specifically designed to provide a solution for file storage and sharing with data protection for your home environment with low power consumption, quiet operation and reliability. Running on DiskStation Manager (DSM) operating system, it delivers ease of use and variety of features.
Synology Disk Station DS213J - NAS server - 6 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
6 TB
Max Supported Capacity
8 TB
2 (installed) / 2 (max)
10 cm x 22.55 cm x 16.5 cm
1 x 1.2 GHz
Storage Controller
RAID - SATA 3Gb/s - RAID 0, 1, JBOD
Hard Drive
2 x 3 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
IP Cameras Supported
5
AC 120/230 V ( 50/60 Hz )
Microsoft Windows XP or later, Apple MacOS X 10.5 or later, Ubuntu 9.04 or later
2 years warranty
NAS server
Host Connectivity
Gigabit Ethernet
6 TB
8 TB
10 cm
22.55 cm
16.5 cm
Built-in Devices
Led panel
Processor / Memory
Processors Installed
1 x 1.2 GHz
RAM Installed
512 MB - DDR3
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD
2 x 3 TB
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Network / Transport Protocol
TCP/IP, PPTP, PPPoE, iSCSI, FTP, DHCP, DNS, DDNS
Remote Management Protocol
SNMP, Telnet, HTTP, HTTPS, SSH
Network Services Compatibility
Microsoft Active Directory (AD), File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, Apple File Protocol (AFP), Web-based Distributed Authoring and Versioning (WebDAV)
Firewall protection, VLAN support, Syslog support, print server, IPv6 support, backup server, download client, Access Control List (ACL) support, RADIUS support, iTunes server, DHCP server, SMS alert, e-mail server, surveillance station, DNS server, cloud backup, VPN Server
Encryption Algorithm
SSL, TLS
DLNA CERTIFIED
Security DVR
5
Expansion Bays
2 (total) / 0 (free) x internal - 2.5" / 3.5"
2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
1 x network cable
Security lock slot (cable lock sold separately), wake on LAN, built-in cooling fan
FCC Class B certified, RoHS, BSMI Class B
TAA Compliant
X external power adapter
19.82 Watt
Software Included
Drivers & Utilities, Synology Assistant, Synology Data Replicator
2 years warranty
Service & Support Details
15 °C
35 °C
5 - 95%
Sound Emission
17 dBA
Customer reviews
Write a review for the Synology 6TB (2 x 3TB WD Red) DS213J 2-Bay Desktop NAS here!
Impressed
Reviewed by Anonymous Review Posted 31/01/2014
I bought the DS213J as a backup device for 3 Windows devices, and also to use as a music server. I didn't want anything too complicated, and since it is sitting in the dining room it had to be small and quiet. I have to say I'm impressed. It was fairly easy to install the disks and set up, and once the basic server is working the browser interface allows you to add additional (free) packages depending on your needs. I added the iTunes server as I wanted to stream music to my iPad, which confusingly it won't do. Not a problem though as Synology also supply an IOS app that talks to their DS Audio Station package, once I installed these everything is working fine.
  • Overall 4*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
