BT.com
Wishlist
Symbol Technologies LS2208 Barcode Scanner
Symbol Technologies LS2208 Barcode...
£81.40
More than 50 in stock
£81.40
Add to wishlist
Delivery
Standard 3-5 working days
The innovative LS 2208 hand-held scanner from Symbol Technologies delivers performance features at an affordable price to make your buying decision easier than ever. If you're seeking investment protection and great value in a small, light scanner that assures maximum productivity, then the LS 2208 is the ideal scanner for you.
From the checkout line to the back room, the LS 2208 helps you make the most of your application-specific solution in a variety of ways.
Getting started with the LS 2208 is fast and simple with 123Scan setup utility. This easy-to-use tool reduces startup time and costs wherever the scanner is used. To further save you money, the scan element in the LS 2208 is based on a liquid injection process that delivers integral shock protection, providing durability you can count on. These powerful features enable you to reduce downtime and keep maintenance costs to a minimum.
In any industry, the high-value LS 2208 hand-held scanner offers superior performance, excellent reliability and user-friendly ergonomics to create a more productive mobile environment. And when you choose the LS 2208, you receive the added assurance of purchasing from Symbol - a company with proven solutions and millions of scanner installations worldwide.
Symbol LS 2208 - barcode scanner
Barcode scanner - handheld - RS-232 - decoded
Scan Element Type
Visible laser diode
Scan Speed
100 scan / sec
Wired
6.3 cm x 8.4 cm x 15.2 cm
146 g
Twilight black
Barcode
Interface Type
RS-232
Scan Element Type
Visible laser diode
Light Source Wave Length
650 nm
Scan Mode
Single-pass
Scan Speed
100 scan / sec
Max Working Distance
43 cm
Skew (Degrees)
60
Pitch (Degrees)
65
Print Contrast Signal (PCS)
20%
Decode Capability
Code 93, Code 39, UCC/EAN-128, IATA, RSS Code, Code 39 Full ASCII, Discrete 2 of 5, Codabar, Code 128, Code 11, UPC, Interleaved 2 of 5, MSI-Plessey
TTL Decoding
Decoded
Wired
OK Notification
Beeper, LED indicator
Advanced Data Formatting (ADF), Reduced Space Symbology (RSS)
1 x RS-232
Stand
1 x serial cable - external
FCC Class B certified, VCCI, EN 60950, ICES-003, IEC950, UL 1950, CSA 22.2 No. 950
Power adapter - external
Software
Software Included
Drivers & Utilities
6.3 cm
8.4 cm
15.2 cm
146 g
50 °C
5 - 95%
Drop Specification
1.5 m to concrete
Buy used stock
What is used stock?
Used stock is a great opportunity to bag yourself a bargain. There are many reasons why a product may be classed as used stock ranging from missing manuals or software to simply having been opened or having damaged packaging. Some items may have been repaired under warranty. Rest assured though that all used stock comes with a 6 month warranty and is in good working order. You can find out the exact details about each product using the key below.
Item condition Customer return - item has been opened but is in excellent condition
Ref: 90MK 035117
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£43.40
Ref: 90MK 035118
  • Accessories
  • Packaging
  • Functional
  • Software
  • Manuals
£43.40
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Scroll to top
