BT.com
Wishlist
Swann Communications PRO-1080FLD Wide Angle Bullet Camera 1080p
Swann Communications PRO-1080FLD...
£91.48
£91.48
Add to wishlist
Delivery
Standard Due date unavailable
  • Seeing is believing with 1080p (2.1 Megapixels) HD perfect for close up detail such as license plates, faces, clothing colors & more
  • See a wider field of view over a shorter distance with the powerful fixed 3.6mm lens
  • Latest infrared cut filter & LEDs produce amazing night vision clarity in low light to 65ft /20m, with sturdy aluminum camera construction to suit indoor & outdoor applications with IP66 rating for any weather conditions
  • Camera features a built-in microphone so you can see & hear what’s happening and longer 100ft/30m cable offers more options when choosing a mounting location for the camera
  • Use the On-Screen Display (OSD) controller & built-in software to customize the camera settings including color, brightness & wide dynamic range for the best video quality every time
  • This camera can be used in combination with other analog HD surveillance technology including AHD, TVI, CVI from Swann & other brands. It’s the perfect addition if you already have a recording solution (DVR) & need extra cameras
  • A compact dome surveillance camera that’s small in size yet has powerful features & it’s perfect for discreet surveillance in wide areas such as offices, entrances, reception areas, living rooms, yards & more
Swann PRO SERIES PRO-1080FLD - CCTV camera
CCTV camera - fixed dome - outdoor - weatherproof
Audio
Yes: built-in microphone
6.9 cm x 6.9 cm x 5.5 cm
195 g
White
Wired
Camera
Colour - Day&Night
Video Modes
1080p
Optical Sensor Type
2.1 MP
Focal Length Control
Fixed focal
Focal Length
3.6 mm
Composite video, HD-CVI, HD-TVI, AHD
1 - BNC cable - external - 30 m
Brightness control, Wide Dynamic Range (WDR), infrared cut filter, On Screen Display
Environmental Parameters (operating)
-20 °C - 50 °C
CCTV camera
Audio Support
Wired
6.9 cm
6.9 cm
5.5 cm
195 g
United Kingdom
Camera
Colour - Day&Night - fixed dome - outdoor - weatherproof
Video Modes
1080p
Infrared LEDs
12
Infrared Distance
20 m
Image Sensor
2.1 MP
Lens Construction
Fixed focal
Focal Length
3.6 mm
Horizontal Field of View (degree)
90
Video
Mounting kit, security stickers
1 x BNC cable - external - 30 m
IP66
White
Power adapter - external
-20 °C
50 °C
Scroll to top
