BT.com
Wishlist
SteelSeries Siberia 800 Headset for PC
Delivery
Standard Due date unavailable
The Siberia 800 wireless gaming headset delivers immersive Dolby surround sound. The wireless headset features a high-quality retractable microphone and is perfect for gaming on PC, Mac, Xbox and Playstation.
Game Breaking Audio
The Siberia 800 cuts the cord to deliver exceptional audio in a brilliantly designed wireless headset. Hear your enemies so clearly, they'll think you're hacking.
Cutting-Edge Compatibility
We've designed this headset to work with all of your devices. Wherever and whatever your entertainment is, Siberia 800 has you covered, just like a trained marksman.
Living Room Elegance
Looks aren’t everything? Tell that to the ugly headsets. The Siberia 800 was designed to resemble a stealth bomber, sleek and deadly. The modern allure of the headset and transmitter are guaranteed to raise eyebrows.
Customizable
The powerful OLED transmitter gives you full control of the features that matter. Customize the balance of voice chat and modify your EQ settings, all on the fly.
Lag Free
Siberia 800 uses continuous frequency hopping technologies to prevent any lag between your game and your headset. The competition waits for interference to be detected before changing channels. We just avoid it completely.
Dolby® Audio
Immerse yourself in incredible virtual 7.1 surround sound. While most headsets simply feature Dolby Headphone, we feature three different Dolby technologies: Dolby Headphone, Dolby Digital, and Dolby Pro Logic IIx.
Low Latency
Siberia 800 delivers the lowest latency in the industry. Period.
Versatility
Siberia 800 works on PC, Mac, Xbox One (with adapter), PlayStation 4, home entertainment systems, phones, and tablets. We even threw in a Sound Share port for when a friend wants to join in on the action.
Couch Control
The on-earcup controls make adjustments quick and intuitive. With the control wheel, you can adjust volume and navigate the most commonly used settings right from your seat.
Swappable Batteries
Never lose power, never go wired. We included two 20-hour lithium-ion batteries, which can be changed mid-action without the hassle of any cables or wires. The spare battery charges inside the transmitter so it's ready when you need it.
Stunning Design
A sleek and stylish mix of matte black and glossy finish are highlighted by SteelSeries Orange stitching for a polished look. Add in comfort to style, memory foam padding on the headband and ear-cups delivers enduring wearability.
Beautiful Display
Profiles, audio sources, battery life, and volume are shown with crystal clear visuals. The large display makes it easy to see and operate from the comfort of your couch.
Chat Mix
You control the audio level balance between the action in your game and the communication from your team. Simply turn up the chat audio to ensure hearing your friends over the explosions. Or turn down your friends if you want to focus on the action.
EQ
Hear what you were meant to with the pre-programmed equalizer. Easily change it with the push of a button for those intense, action-packed movies, or switch to Music when feeling those slow jams.
SteelSeries Siberia 800 - headset
Headset - 7.1 channel - wireless
Recommended Use
Game console, computer
Matte black
Headphones Form Factor
Full size
Wireless
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 20 - 20000 Hz - Sensitivity 100 dB
Microphone
Boom
297 g
Matte black
Recommended Use
Max Operating Distance
10 m
Headphones
Circumaural
Wireless
Available Microphone
Sound Output Mode
Stereo
Frequency Response
20 - 20000 Hz
Sensitivity
100 dB
Diaphragm
40 mm
Magnet Material
Neodymium
Microphone
Boom
Sensitivity
-44 dB
Impedance
2.2 kOhm
Frequency Response
100 - 10000 Hz
Audio Input Details
Uni-directional
Wireless Link
Transmission Range
10 m
Audio (optical) cable , USB cable , RCA cable , Audio cable
Transmitter unit, 2 battery packs, mobile cable, chat cable
Headset battery rechargeable - Lithium Ion
1000 mAh
Run Time (Up To)
20 hour(s)
Scroll to top
