Click to visit BT.com
BT.com
Wishlist
SteelSeries Kinzu v2 - Mouse - optical - 4 button - USB - white
Quicklinx: 8CGNWS00
Mfr#: 62040
Size doesn't matter. Really.
Developed With The Best
We are proud to be associated with some of the best players in the world of eSports. We maintain strong relationships and have continuous dialogue with teams like Natus Vincere, SK Gaming, Fnatic, Evil Geniuses and others who help in the development and improvement of our products.
To ensure maximum performance in all gaming scenarios we enlisted help from world-class StarCraft® II, Counter-Strike, DotA, League of Legends, Heroes of Newerth, WarCraft® III and Doom players.
Size and weight
-Weight: 77 grams (0.17 lbs)
-Height: 36 mm (1.4 in)
-Width: 64 mm (2.5 in)
-Length: 117 mm (4.6 in)
Superior tracking
The SteelSeries Kinzu v2 uses advanced, optical technology that operates at 3600 Frames Per Second and supports stable movement speeds at 65 Inches Per Second. These specs simply say that regardless of your frantic movements, the mouse will consistently deliver, especially for fast-paced FPS games.
Ambidextrous
The SteelSeries Kinzu v2 is designed for extended use. Its ergonomic and ambidextrous design makes it a natural fit for both right and left handed users.
The SteelSeries Engine
The SteelSeries Engine allows you to customize your mouse settings like never before. With the SteelSeries Engine installed you are able to:
-Set custom CPI settings
-Program your mouse buttons
-Set polling rate
-Record macros
-Track button usage statistics
-Set game triggers for profiles
-Setup unlimited profiles for the settings above...
Shaped for Comfort
The SteelSeries Kinzu v2 is ergonomically shaped to comfortably fit all three grip styles - claw, palm and swipe - for easy reach to all 4 buttons whether the user is playing a fast-paced FPS game or even a long session MMO game.
Easy To Adjust CPI
The centrally located toggle button allows you to quickly switch between two sensitivity settings. The pre-defined CPI settings in the Kinzu v2 are used and recommended by professional gamers all over the world. These CPI settings are also easily adjustable if you want to personalize your Kinzu v2 via the SteelSeries Engine software.
Mouse glides
Material: high performance UPE material covers 16 % of mouse bottom to ensure maximum glide. We recommend changing glides regularly as they will eventually be worn down
Stability
The SteelSeries Kinzu v2 is made to be stable on every kind of surface with the help of its optical sensor. This sensor is also designed to eliminate jitter and provide optimized stability for the user.
Double Braided cord
-USB 2.0 connector
-Anti-tangle braided cord for enhanced durability
-Cord length: 2 meters (6.5 feet)
SteelSeries Kinzu v2 - mouse - USB - white
Mouse
Wired - USB
White
Orientation
Right and left-handed
6.4 cm x 11.7 cm x 3.6 cm
77 g
Movement Detection Technology
Optical
Buttons Qty
4
Movement Resolution
3200 cpi
Accuracy
± 2 mm
Performance
30 G maximum acceleration, up to 65 inches per second, realtime sensitivity switching 400 - 3200 cpi, 3600 fps, 3.7 megapixels per second
Teflon feet, braided cable
1 x USB cable - integrated - 2 m
Apple MacOS X, Microsoft Windows 2000/XP/Vista/7
2 years warranty
Mouse
Orientation
6.4 cm
11.7 cm
3.6 cm
77 g
White
Input Device
Wired
USB
Optical
Buttons Qty
4
Movement Resolution
3200 cpi
Accuracy
± 2 mm
Performance
1 x USB 2.0 - 4 pin USB Type A
Software Included
SteelSeries Engine
2 years warranty
Service & Support Details
