BT.com
Wishlist
StarTech.com Wireless HDMI Extender - 165ft
StarTech.com Wireless HDMI Extender...
£333.67
£333.67
Add to wishlist
Delivery
Standard 1-3 working days
Wirelessly extend an HDMI signal up to 165 ft (50m), with the added benefit of IR extension for remote control of your video source. This HDMI over wireless extender lets you transmit your audio / video signal from an HDMI source to a remote display located up to 165 ft (50m) away. The extender kit uses Wi-Fi to transmit an uncompressed, high-definition 1080p HDMI signal, as well as an IR signal for controlling your source device remotely.
With wireless video extension, you can extend or mirror your laptop computer to share documents or multimedia content (including music, video, and pictures) in full HD, perfect for sharing ideas with your colleagues on a boardroom projector or tradeshow display.
The HDMI over wireless extender offers a practical alternative to traditional copper video cabling, which saves your budget by avoiding the cost of installing an expensive wiring infrastructure.
This bundled kit includes both the transmitter and receiver, saving you the hassle and expense of buying multiple devices to accomplish one task.
The extender is great for digital signage applications because it lets you install your display wherever you want, unlike wired solutions that force you to compromise on the location of your display based on the available cabling.
This wireless video extender is very easy to install and use. With simple plug-and-play installation, setup is as easy as connecting the video cables and turning on the extender. The wireless video extender is a pure hardware solution that doesn't require any software or drivers, saving you time by avoiding complicated software installation and configuration.
With hassle-free operation you don't need to be an A/V technician to use this extender, which makes it a great solution for commercial markets such as retail storefronts and lobbies, as well as healthcare and education facilities.
With a wide assortment of convenient features, this HDMI over wireless extender accommodates virtually any remote video application. You can transmit your audio and video to a remote location with less than 100 milliseconds of latency, making this extender suitable for interactive applications such as remote touchscreens and video games. To keep your video transmission secure, the extender uses AES 128 to 256 encryption.
The HDMI over wireless extender also works to extend an infrared signal, enabling you to control your video source from the remote location. Easy-to-install mounting brackets are also included with the wireless extender kit for tidy, professional installation.
StarTech.com HDMI over Wireless Extender - Wireless HDMI - 1080p - video/audio/infrared extender
Video/audio/infrared extender
External
Max Transfer Distance
50 m
AC 120/230 V
5.8 cm x 10 cm x 2 cm
136 g
2 years warranty
External
Wireless
Max Resolution
1920 x 1080 / 1080p
50 m
Status Indicators
Link/activity, video
1 x HDMI
IR receiver, IR transmitter
1 x HDMI cable
Rack Mounting Kit
Included
FCC, RoHS
External power adapter
AC 120/230 V
5.8 cm
10 cm
2 cm
136 g
5 - 90%
Scroll to top
