BT.com
Wishlist
StarTech.com video / audio cable - 3 m
Delivery
Standard Due date unavailable
The HDMIMM10 10-foot High Speed HDMI cable features 2 gold-plated HDMI (male) connectors and durable high quality construction to provide a dependable HDMI to HDMI connection between devices such as Blu-Ray players, HDTVs, DVD Players, stereo receivers and more.
This high quality HDMI cable fully supports 1080p+ resolutions at up to 120Hz refresh rate, with life-like color; to accommodate the demands of future high definition devices, such as increased resolutions and higher frame rates, StarTech.com HDMI cables can support bandwidth up to 340 MHz (10.2 Gbps) and display resolutions of up to 1440p.
StarTech.com High Speed HDMI digital video and audio cables are expertly designed and constructed of only top quality materials to ensure high quality, high definition performance. The HDMI standard combines high bandwidth video and multi-channel digital audio into a single cable, and provides crystal clear image resolution.
This product has been replaced by StarTech.com's 10 ft High Speed HDMI Cable HDMM10.
StarTech.com High Speed HDMI Cable - HDMI cable - 3 m
Cable
HDMI cable
Length
3 m
Connector
HDMI Type A - male
Connector (Second End)
HDMI Type A - male
P/N: HDMI2VGA, IPUSB2HDMI, SV231HDMIUA, DVI2HDMI, HDMI2HDMI, ST121HDMR50, ST121HDMIT, VS410HDMIE, CPNTA2HDMI, HDMI2DVI, CPNTTOS2HDMI, VS810HDMIR, ST124HDMI, ST122HDMI, VGAHD2HDMIGB, VGAHD2HDMI
Cable Type
HDMI cable
Length
3 m
Connector
19 pin HDMI Type A - male
Service & Support Details
Limited warranty - lifetime
StarTech.com 2 Port HDMI Video Splitter and Signal Amplifier, 2 Port USB HDMI KVM Switch with Audio and USB 2.0 Hub, 4 Port HDMI Audio / Video Splitter, 4-to-1 HDMI Video Switch with Remote Control, Component and Toslink to HDMI Video Converter with Audio, Component to HDMI Video Converter with Audio, DVI and Digital Audio to HDMI Converter, Ethernet or USB to HDMI Converter, HDMI over Cat 5 Video Extender - Receiver, HDMI to DVI-D Video Converter with Audio, HDMI to VGA Video Adapter Converter w/ Audio HD to VGA Monitor, HDMI Video Extender over Cat 5, VGA to HDMI Video Converter with Audio , StarTech.com Converge A/V 8 to 1 HDMI Switch with Remote and RS-232 Control, Component with Audio to HDMI Format Converter, HDMI Over CAT5 / UTP Receiver, HDMI to DVI-D with SPDIF Audio Converter
Scroll to top
