BT.com
Wishlist
StarTech.com VGA to HDMI Video Converter with Audio - video converter - black
Delivery
Standard Due date unavailable
Connect a PC with VGA output to work with an HDMI display or monitor.
The VGA2HDMI VGA HD to HDMI video converter with Audio allows you to convert an analog RCA audio signal and VGA video to a single HDMI cable. A great way to adapt your PC video signal enabling you to view multimedia content from your computer on your HDTV the way it was meant to be seen and heard.
This HD15/VGA (with RCA Audio) to HDMI format converter is a great way to wow your audience with the full power of digital content, supporting input resolutions of up to 1080p for HD and 1600x1200 for PC. The VGAHD2HDMI device also supports converting a Component signal to HDMI using the included Component to VGA adapter cable.
Video converter
1 x audio line-in - RCA x 2 , 1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x HDMI output - 19 pin HDMI Type A
7.6 cm x 10.5 cm x 3 cm
Enclosure Colour
2 years warranty
Video converter
1 x audio line-in - RCA x 2 - female , 1 x VGA input - 15 pin HD D-Sub (HD-15) - female , 1 x HDMI output - 19 pin HDMI Type A - female
Video Output
Supported Display Graphics
UXGA (1600x1200)
7.6 cm
10.5 cm
3 cm
Enclosure Colour
Limited warranty - 2 years , Technical support - lifetime
Accessories
£6.90
£4.39
Scroll to top
