BT.com
Wishlist
StarTech.com VGA to HDMI Adapter with USB Audio & Power- Portable VGA to HDMI Converter 1080p
StarTech.com VGA to HDMI Adapter...
£37.20
More than 50 in stock
£37.20
Add to wishlist
Delivery
Standard 3-5 working days
Convert a VGA signal from a laptop or desktop to HDMI (USB-Powered). The VGA2HDU VGA to HDMI adapter lets you turn the VGA port on your Desktop or Laptop computer into an HDMI output port.
With the VGA2HDU, you can expand your VGA video output to accommodate the increasing number of displays and projectors that only support HDMI.
Not all VGA converters are created equal. This adapter ensures you're harnessing the highest video quality from your VGA output, with support for resolutions up to 1920x1080 (1080p).
For hassle-free setup the VGA to HDMI adapter allows for plug-and-play installation. Plus, with a built-in USB power cable the device is powered using the USB port on your computer. The VGA to HDMI adapter will work with any computer operating system, but when working with a Windows computer the adapter supports native USB audio, allowing you to add your computer audio to the HDMI signal.
StarTech.com VGA to HDMI Portable Adapter Converter w/ USB Audio & Power video converter - black
Video converter
Bus Type
VGA
Max Resolution
1920 x 1080
1 x VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB 2.0 - 4 pin USB Type A , 1 x HDMI output - 19 pin HDMI Type A
3.5 cm x 26 cm x 1.5 cm
Enclosure Colour
2 years warranty
Video converter
Bus Type
VGA
Max Resolution
1920 x 1080
1 x VGA input - 15 pin HD D-Sub (HD-15) - male , 1 x USB 2.0 - 4 pin USB Type A - male , 1 x HDMI output - 19 pin HDMI Type A - female
USB powered, USB audio interface
Microsoft Windows Vista / XP / 7 / 8
1 x USB extension cable - 60.98 cm
WHQL, FCC, RoHS
3.5 cm
26 cm
1.5 cm
62 g
Enclosure Colour
60 °C
40 - 85%
Accessories
£7.11
Scroll to top
