BT.com
Wishlist
StarTech.com VGA to Cat 5 Monitor Extender Kit (250ft/80m) - VGA Cat5 Extender
StarTech.com VGA to Cat 5 Monitor...
£133.12
16 in stock
£133.12
Add to wishlist
Delivery
Standard 1-3 working days
Extend a VGA signal to a remote display using Cat5 cabling.
The ST121UTPEP VGA Video Extender over Cat5 - Point to Point lets you connect a remote VGA display/projector up to 80m (250ft) away from the VGA signal source. The ST121UTPEP is a bundled kit that includes both a local and a remote unit providing a complete end to end solution for a single source/display connection, transmitting the source VGA signal over a standard Ethernet cable (Cat5e or better UTP cable, terminated with RJ45 connectors).
Offering convenient and cost-effective VGA distribution, the ST121UTPEP only requires one power adapter which can be installed at either the local or remote end of the connection, depending on what is most convenient for your application.
To ensure a tidy installation, the ST121UTPEP includes a mounting bracket for the receiver to help eliminate unnecessary cable tangles.
StarTech.com VGA to Cat 5 Monitor Extender Kit 250ft/80m VGA Extender - video extender
Video extender
External
Max Transfer Distance
80 m
10 cm x 13.8 cm x 2.5 cm
36 g
2 years warranty
Video extender
External
Wired
Max Resolution
1920 x 1200
80 m
1 x VGA - HD-15
1 x VGA cable
FCC, RoHS
External power adapter
10 cm
13.8 cm
2.5 cm
36 g
Accessories
£6.90
£15.70
£57.19
£6.90
£13.86
£26.24
£11.46
£15.79
Scroll to top
