BT.com
Wishlist
StarTech.com USB VGA Console Extender over CAT5 UTP (500 ft)
StarTech.com USB VGA Console...
£173.60
£173.60
Add to wishlist
Delivery
Standard 1-3 working days
This USB VGA KVM console extender lets you control a server, computer or multiple computers (connected through KVM switch) over a standard Cat5 or Cat6 UTP network cable connection, at distances of up to 500ft away. PC connection cables are included with this product for a ready out of the box solution.
You can use your existing keyboard, mouse, and monitor to access both the server room and your office computer, saving space and avoiding the need for a dedicated remote console by allowing you to switch between workstation view and KVM view at the remote location.
The USB VGA console extender is designed to provide long lasting, reliable operation.
StarTech.com USB VGA KVM Console Extender over CAT5 UTP - KVM extender
KVM extender
External
United Kingdom
Max Transfer Distance
150 m
15.5 cm x 7.5 cm x 2 cm
299 g
2 years warranty
KVM extender
External
United Kingdom
Wired
Max Resolution
1024 x 768
150 m
1 x USB mouse , 1 x USB keyboard , 1 x VGA - HD-15 , 1 x KVM - HD-15
2 x keyboard / mouse / video cable
FCC, RoHS
External power adapter
15.5 cm
7.5 cm
2 cm
299 g
Scroll to top
