BT.com
Wishlist
StarTech.com USB to VGA Multi Monitor External Video Adapter
StarTech.com USB to VGA Multi...
£38.74
Hurry, only 3 left in stock!
£38.74
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Wednesday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The USB2VGAE2 USB to VGA external video adapter is the perfect multi-monitor VGA solution for office applications and Internet browsing.
The USB video adapter features a small form factor and enables a USB 2.0 port to be used with a VGA port. A cost-saving multi-monitor or dual display option that can be used as an external graphics card for either laptop or desktop applications.
The USB video adapter can be used with up to four additional (five total) USB2VGAE2 USB video adapters, creating multiple VGA connections that can be used to further extend or mirror the desktop shown on the existing display - all without having to open the computer case to add extra video cards.
StarTech.com USB to VGA Multi Monitor External Video Adapter external video adapter - 16 MB - grey
External video adapter
Bus Type
USB 2.0
16 MB SDRAM
Max Resolution
1680 x 1050
VGA
4.2 cm x 7.5 cm x 5 cm
Enclosure Colour
Grey
2 years warranty
Bus Type
USB 2.0
Max Resolution
1680 x 1050
VGA
Size
16 MB
SDRAM
Video Output
Supported Display Graphics
XGA (1024x768), SVGA (800x600), SXGA (1280x1024), SXGA+ (1400x1050), UXGA (1600x1200), 1152x864, 1280x960, 1280x800, 1440x900, 1280x768, 1680x1050
Colours Max Resolution (external)
32-bit colour
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Additional Requirements
USB 2.0 port
1 x USB cable - 45.72 cm
Software Included
Drivers & Utilities
Plug and Play, FCC, RoHS
4.2 cm
7.5 cm
5 cm
120 g
Enclosure Colour
Grey
Accessories
£15.70
£6.90
£11.46
Scroll to top
