Click to visit BT.com
BT.com
Wishlist
StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD
5.0*
Quicklinx: 6Q9KWS00
Mfr#: SATDOCK25U
Type: HDD docking station
HD Size: 2.5"
Power Supply: None
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£8.47
Enable external, hot-swap access to 2.5in SATA drives from a portable mini USB2.0 drive dock.
The SATDOCK25U Hard Drive Docking Station provides full, instant access to any 2.5in SATA (SATA, SATA II, SATA III) hard drive or solid state drive - without having to mount the hard drive in a computer or install it in an enclosure!
This highly compact HDD dock offers the portability needed to add simple external storage to virtually any USB-capable computer, making it a definite asset to have on hand to connect external (bare) hard drives even in mobile computing applications. Plus, its small form factor design requires minimal space on a desktop or work bench. Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
Simply insert a 2.5in SATA hard drive or SSD into the dock, then connect the hard drive dock to a host computer through USB 2.0. To uninstall or swap the hard drive, simply disconnect the USB cable and remove the drive from the dock!
In addition to providing a fast convenient way to access or recover data from a mobile 2.5in drive this dock is completely USB powered, so no power adapter is required. The HDD Dock supports plug and play hard drive installation on most operating systems, and offers data transfer speeds of up to 480Mbps - a convenient alternative to external hard drive enclosures that saves the time needed to prepare the drive for conventional installation.
StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD - HDD docking station - SATA 3Gb/s - USB 2.0
HDD docking station - external
Bays
1
Bus Type
USB 2.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic
Power Source
Included AC adapter
Linux, Maxtor NAS OS 2.0 or later, Microsoft Windows 2000/ME/XP/Vista/7
2.5 cm x 8.2 cm x 3.6 cm
30 g
2 years warranty
Bays
1
2.5"
Host Bus
USB 2.0
Product Material
Plastic
Storage Controller
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
1
JMicron JM20329
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - 15 pin Serial ATA power , 1 x SATA 3Gb/s - 7 pin Serial ATA
1 x USB 2.0 - mini-USB Type B
1 x USB cable - external
Tested with up to 1TB 5400 RPM hard drives
Plug and Play, FCC, RoHS
Power Source
Included AC adapter
Power adapter
2.5 cm
8.2 cm
3.6 cm
30 g
5 °C
80 °C
0 - 90%
StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD Bundle deal on StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£10.25
saving £1.78
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£12.56
saving £1.39
6Q9K StarTech.com 6 ft Mini USB Cable - A to Mini B In Stock £3.68
6Q9K StarTech.com 3 ft Mini USB 2.0 Cable - A to Mini B In Stock £3.56
6Q9K StarTech.com 10 ft USB 2.0 Cable - USB A to Mini B In Stock £3.84
6Q9K StarTech.com 2.5in Silicone Laptop Hard Drive Protector Sleeve with Connector Cap In Stock £4.47
6Q9K StarTech.com 1 ft Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.67
6Q9K StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD In Stock £8.47
6Q9K StarTech.com 2.5in Anti-Static Hard Drive Protector Case - Black (3 Pack) In Stock £11.61
Customer reviews
Write a review for the StarTech.com USB to SATA External Hard Drive Docking Station for 2.5in SATA HDD here!
Excellent piece of kit!
Reviewed by Nick P. Review Posted 04/10/2013
I needed to recover data from a dead laptop's hard drive and this made it a very quick and simple job. An added bonus is that I now have a docking station to allow old SATA drives to be used as backup storage.
There are lots of similar solutions out there but costing 2-4 times as much and many also require external power supply. This is powered solely through the supplied USB 'Y' cable and is simplicity itself to use - insert SATA drive, connect USB cable and 'voila', extra drive now accessible from Windows Explorer.
A compact, neat solution which doesn't require a seperate power supply and does exactly what it says on the tin. You could do far worse than buying this item.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Handy Device
Reviewed by Bigtallbill. Review Posted 02/02/2011
This dock works exactly as it should, The unit comes with a Y USB cable so you can plug both connectors if your drive needs more power.
The unit has a handy flip-out stabilization arm to keep it steady.
Currently using mine with a 250 Western Digital drive. My only criticism is that most of the drive is exposed due to the nature of the dock.
  • Overall 4*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
HD Size: 2.5"
Power Supply: None
Price Range Inc VAT: 0 - 50
