BT.com
Wishlist
StarTech.com uSB to RS-232 Serial DB9 Adaptor
Delivery
Standard Due date unavailable
Add one serial RS-232 port to any laptop or computer with a USB port. The StarTech.com ICUSB232 1ft USB to DB9 RS232 Serial Adapter Cable lets you connect DB9 RS232 serial devices to your Mac or PC laptop or desktop computer through a USB port, as though the computer offered an onboard DB9M connector.
A cost-effective solution that bridges the compatibility gap between modern computers and legacy serial peripherals, as well as offering compatibility with nearly all PLC Brands (AllenBradley, Siemens, Modicon, Servos, Indramat, Siemens, AB, etc.).
StarTech.com USB to DB9 Serial Adapter Cable - serial adapter
Serial adapter
External
Interface (Bus) Type
USB
Ports
RS-232
RS-232
Data Transfer Rate
115.2 Kbps
Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
2 years warranty
P/N: ST4205USBGB, ST4205USBEU, ST4205READGB, ST4205READEU, ST4205USB, ST4205READ
Serial adapter
External
USB
Ports
RS-232
Wired
RS-232
Data Transfer Rate
115.2 Kbps
Status Indicators
Active
1 x RS-232 - 9 pin D-Sub (DB-9) - 1
1 x USB - 4 pin USB Type A
1 x serial cable ( integrated ) - 0.3 m
2 years warranty
Service & Support Details
Limited warranty - parts and labour - 2 years
5 °C
0 - 80%
StarTech.com 3 Port USB 2.0 Hub & 16-in-1 Multi Media Memory Card Reader, 4 Port Silver USB 2.0 Hub
Accessories
£4.38
£4.26
£16.42
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* very good 5
Reviewed by alfbrimming on 31/12/2011
I have looked for a month for this item each day for three hours a day, for this cable that will work on vista 7, no dealer sells it this seems to be the best answer so far BT have done it again and come out on top. best dealer in the UK keep it up lads. alf brimming
5* OSX Mavericks = YES!!
Reviewed by James Saunders on 18/07/2014
I have like many others lost the will to live searching and trying to get a serial adapter to work with OSX. All I wanted to do was plug it in, open Spider Serial Terminal (app store) select the adaptor from the drop down, set the speeds, turn on a Cisco device and da daaaa..
This is exactly what it did. No drivers, no messing about. Plug it in and you are good to go. Quality seems nice as well. Am tempted to buy another in case these leave the planet!
I have tried ones from eBay and all sorts. This is cheap compared to the nightmare so don't waste time searching around.
5* Does exactly what it says on the tin!!
Reviewed by Matt on 24/07/2006
Works exactly like you had a serial port built into your machine.... never had any problems and good value for money.
5* This is the one to get
Reviewed by JJ on 04/11/2006
I reviewed several for a client and this is the only one that worked flawlessly. Not the cheapest but the only one we'll be using in future.
4* You will need to download drivers
Reviewed by Anonymous on 01/05/2008
Seems to work, but you will need to download the drivers from the startech website. The supplied disk does not contain the right drivers.
4* Works well, but poor documentation
Reviewed by David Biggins on 28/03/2009
The device itself works well once installed, although this took some time. The supplied instructions are for Windows 2000 only and even then refer to drivers not supplied on the CD-ROM. The CD-ROM itself is confusing having drivers for several devices none of which seemed to match the device exactly.
Trial and error finally got it working.
Scroll to top
