BT.com
Wishlist
StarTech.com USB to IDE SATA Standalone HDD Hard Drive Duplicator Dock
StarTech.com USB to IDE SATA...
£191.24
£191.24
Add to wishlist
Delivery
Standard 1-3 working days
Clone any combination of 2.5in or 3.5in IDE or SATA hard drives.
The UNIDUPDOCK Universal SATA/IDE Dual Hard Drive Duplicator functions as both a convenient solid state (SSD) or hard drive (HDD) copying/imaging solution or an external SATA/IDE SSD or HDD docking station for 2.5in or 3.5in drives (SATA, SATA II, SATA III).
Providing quick, yet complete hard drive cloning functionality, this universal dock can operate as a standalone HDD duplicator with no connection to a host computer, delivering an exact 1 to 1 clone of the target hard drive including partition and boot sector information, the Host Protected Area (HPA) as well as user data at a copy rate of 72 MB/sec. A built in LCD screen then allows for tracking the duplication progress, as well as reporting errors on the drives.
Supporting both IDE and SATA, this universal duplicator dock enables duplication from SATA to SATA, IDE to SATA or SATA to IDE, and IDE to IDE, as long as the source drive does not exceed the size of the destination drive. Or the docking station can even be used to quickly erase hard drives, for reuse in the future.
Functioning as a universal IDE and SATA HDD docking station, the hard drive duplicator can be connected to a computer through USB with support for simple plug-and-play installation, allowing users to access hard drive contents without having to mount in an external drive enclosure or open the computer case for conventional drive installation. Large capacity drives (tested with up to 4TB 3.5" and 1TB 2.5" drives per bay) can be used to greatly enhance your computer's storage/backup capabilities.
Contained in a small form factor design that makes it a suitable addition to desktop and laptop operating environments, this hard drive duplicator/external HDD docking station is a versatile storage and hard drive cloning utility that also features a host of other built in utilities that are accessible via a built in menu system.
StarTech.com USB to IDE SATA Standalone Hard Drive Duplicator Dock HDD - hard drive duplicator
Hard drive duplicator
USB 2.0
0 (installed) / 2 (max)
Supported Drives
IDE / SATA
Storage Controller
SATA/IDE ( IDE / SATA-300 ) - RAID 0, 1, JBOD
Hard Drive
No HDD
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
AC 120/230 V - 50/60 Hz
11 cm x 15.1 cm x 2.7 cm
235 g
1 year warranty
Enclosure Colour
Chassis
0
Supported Devices / Modules Qty
2
Supported Drives
IDE / SATA
Storage
HDD Array External Interface
USB 2.0
Storage Controller
SATA/IDE - integrated ( USB 2.0 )
Interface Type
IDE / SATA-300
Supported Devices
Hard drive
Max Storage Devices Qty
2
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
No HDD
Expansion Bays
2 (total) / 2 (free) - 2.5" / 3.5" shared - external
1 x USB 2.0 - 4 PIN USB Type B , 2 x eSATA 3Gb/s - 7 pin external Serial ATA , 2 x IDE/ATAPI - 40 PIN IDC
Tested with up to 4TB 5400 RPM 3.5” hard drives, tested with up to 1TB 5400 RPM 2.5” hard drives
FCC, RoHS
External power adapter
11 cm
15.1 cm
2.7 cm
235 g
1 year warranty
Service & Support Details
Limited warranty - 1 year
5 °C
80 °C
Accessories
£5.67
£5.20
£4.56
£4.58
£4.69
£7.82
£191.24
£10.90
£20.91
Scroll to top
