BT.com
Wishlist
StarTech.com USB S-Video and Composite Video Capture Device Cable with Audio
Delivery
Standard Due date unavailable
Capture DVDs or VHS to your PC. The SVID2USB2 USB 2.0 S-video/composite video capture cable lets you connect devices that output S-video or composite video to a computer through an available USB 2.0 port. The cable also features two channel RCA stereo audio inputs that let you capture the audio accompanying the S-video or composite video signal.
The perfect solution for bridging a computer and an S-video or composite video source, the capture cable offers real time MPEG 1, MPEG 2 and MPEG 4 recording. Small enough to fit in the palm of your hand, the capture cable is a great solution for mobile applications that integrates seamlessly with laptop and desktop computers.
StarTech.com S-Video & Composite to USB Video Capture Device Cable w/ Audio - video capture adapter - USB 2.0
Video capture adapter
Interface Type
USB 2.0
Video Input
S-video input, composite video input
Analogue Video Format
NTSC, SECAM, PAL
Analogue video Signal
S-Video, composite video
Digital Video Format
MPEG-1, MPEG-2, MPEG-4
Frame Rate
NTSC: 30 frames per second
Digital Video Capture Resolution
720 x 480, 720 x 576
Audio Input Support
Standard
Sharpness control, brightness control, contrast control
Microsoft Windows 2000, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
2 years warranty
Interface Type
USB 2.0
Video
Interface Type
NTSC, SECAM, PAL
Frame Rate
Audio Input Support
Standard
1 x display / video - composite video input - RCA , 1 x display / video - S-video input - 4 pin mini-DIN , 1 x audio - line-In - RCA x 2
1 x USB 2.0 - 4 pin USB Type A
Plug and Play, FCC, RoHS
Limited warranty - 2 years , Technical support - lifetime
Scroll to top
