BT.com
Wishlist
StarTech.com USB-C microSD Reader/Writer USB 3.0
StarTech.com USB-C microSD...
£17.11
£17.11
Add to wishlist
Delivery
Standard Due date unavailable
Transfer data quickly from your microSD card to your USB-C enabled smartphone, tablet, or computer. This card reader/writer gives you a fast and easy way to transfer photos and videos between your microSD memory card and your laptop, tablet, smartphone, or other USB-C device. It makes it easy to take your microSD card data with you wherever you go, with its compact, portable design.
Quickly offload the data from your microSD card so that you can instantly view, listen to and evaluate your work or replay your experiences.
It's the ideal solution for transferring high-definition videos, high-resolution photos, music and other data files from your video and audio recording device, digital camera, and other portable devices to your USB Type-C enabled smartphone, tablet or laptop.
Through USB 3.0 (also known as USB 3.1 Gen 1), the card reader/writer provides data transfer speeds of up to 5Gbps. The adapter is also compatible with Thunderbolt 3 USB-C ports and backward compatible with USB 2.0, 1.x devices.
The card reader's compact form factor makes it easy to take with you wherever you go, to quickly share content from your digital camera or another device. Its unique design enables you to turn your microSD card into a portable thumb drive that's compatible with the latest smartphones, tablets, laptops and other USB Type-C enabled devices.
It also comes with a cover that fits over the slot to protect your microSD card when it's not in use.
The USB 3.0 card reader/writer is ready to go. It's OS independent, so you don't have to install additional drivers or software. It is also USB powered so it does not require an additional power source.
StarTech.com USB 3.0 Card Reader / Writer for micro SD Cards - USB Type-C - card reader - USB 3.0
Card reader - external
Supported Memory Cards
microSD, microSDHC, microSDXC
Host Interface
USB 3.0
2 years warranty
Host Interface
USB 3.0
2.2 cm
0.74 cm
2.88 cm
3 g
Required Ports
1 x 24 pin USB Type C
FCC, RoHS
Scroll to top
