BT.com
Wishlist
StarTech.com USB 3 to VGA Video Adapter
Delivery
Standard Due date unavailable
Connect a VGA display through a SuperSpeed USB 3.0 port for an accelerated external multi-monitor solution. The USB32VGAE USB 3.0 to VGA Adapter turns an available USB 3.0 port into a VGA output with support for high resolution video (up to 2048x1152) - a convenient external video solution that makes it easy to add multi-monitor/dual display capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0 connection, backward compatible with USB 2.0 connection). Leveraging the high-bandwidth (up to 5 Gbps) SuperSpeed USB 3.0 interface, the adapter functions as an external graphics card to deliver smooth, high-resolution content to your VGA display; the adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
What's in the box
  • StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter 2048x1152
  • USB cable - 16 cm
StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter 2048x1152 - external video adapter - T5-302 - 16 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
MCT Trigger 5 T5-302
16 MB DDR2
Max Resolution
2048 x 1152
VGA
4.4 cm x 7.8 cm x 1.6 cm
Enclosure Colour
2 years warranty
Bus Type
SuperSpeed USB 3.0
Graphics Engine
Max Resolution
2048 x 1152
VGA
USB powered
Size
16 MB
DDR2 SDRAM
Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Min Processor Type
Quad core processor 2.4 GHz
Min RAM Size
4 GB
Additional Requirements
USB port
1 x USB cable - 16 cm
FCC, RoHS
4.4 cm
7.8 cm
1.6 cm
300 g
Enclosure Colour
55 °C
0 - 85% (non-condensing)
Scroll to top
